AIR SUSPENSION ISSUES
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TXTRUCKER75479, Dec 16, 2020.
  1. TXTRUCKER75479
    TXTRUCKER75479 Bobtail Member
    7
    Dec 16, 2020
    Having issues with air suspension on 2016 KW T680.
    Air suspension is dumping automatically(by itself) from every 3 min. to 30 min. or when ever it feels like it. It's not the leveling valve. Just replaced it. It started doing this about a month or 2 after having the main computer updated. Has anyone else had/have this issue
  3. MRMTRANS
    MRMTRANS Medium Load Member
    407
    440
    Apr 28, 2015
    Yes. It's not related to the computer. Get a spray bottle with some dish was soap and water and start spraying and looking for bubbles. The air leak can be just about anywhere you see an airline. Check the bleed off valves on the air tanks, too.
    alds Thanks this.
  4. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
  5. MRMTRANS
    407
    440
    Apr 28, 2015
    It just occurred to me that maybe you should hear the leak, since it is sometimes taking 3 minutes. Air leaks in bags commonly develope on the part of the rubber that can't be seen, along c the piston (bottom portion).
    TXTRUCKER75479 Thanks this.
  6. TXTRUCKER75479
    7
    Dec 16, 2020
  7. TXTRUCKER75479
    7
    Dec 16, 2020
    It's not an air leak. If that was the case bags would not air up. Something is signaling the dump solenoid to dump. I can stop and flip the dump switch or turn the truck key off and back on and it airs back up. I've been switching key off&on while going down to road to keep from stopping
  8. IH Truck Guy
    4,915
    57,030
    Mar 2, 2008
    Purgatory
    It's a computer issue.
    Something changed when they did the upgrade.
    You can't work on this new crap without a computer hooked up.
    Sad state of affairs.
    black_dog106, TXTRUCKER75479 and 062 Thank this.
  9. MRMTRANS
    407
    440
    Apr 28, 2015
    You might be right about a dump solenoid. I still have an old ruck with a mechanical dump valve. But air bags can still air up if the leak is small enough. I've had that occur 2 times: once on a trailer suspension bag and once on a cab bag. In both cases The leak was along the portion of the bag tucked underneath by the piston. I suppose they were small enough that more air flowed into the other bags, enough to raise the suspension than leaked out.
  10. TXTRUCKER75479
    7
    Dec 16, 2020
    I've had several of those bag leaks. This is not one of those. It'll dump just sitting. It's very annoying. I hate electrical or computer issues
  11. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    You will follow the air line up to a bank of EOA solenoids. I would suggest swapping the solenoids to control another device. If the problem moves with the EOA and your dump is OK, that EOA is bad. If it stays the same its electrically being told to open/ wiring or control issue.
    Electric over air solenoid.
    Not 100% on location but they should be below the cab. Mutiple 1/4 " nylon air lines, bank of them.
