Air suspension problem need help
Discussion in 'Peterbilt Forum' started by 2015 vlad, Jan 3, 2020.
  1. 2015 vlad
    2015 vlad Bobtail Member
    4
    You
    I have 2015 Peterbilt 389( car hauler). I picked up the truck from Peterbilt service few days ago. I got clutch and air leak fixed. After pickup, the airbags keep pumping the truck higher from normal levels, and then goes back down normally, and this is constant occurrence. I replaced a leveling valve and that didnt do anything. What happened to the truck while it was being serviced? Because this wasnt a problem before.
  3. Lyle H
    Lyle H Road Train Member
    1,291
    2,937
    Apr 16, 2014
    Did you call the place that worked on it and ask them?
    stillwurkin Thanks this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    You should have papers detailing exactly what was done on the truck.
