air system. need help!!!!
Discussion in 'Freightliner Forum' started by Fireman07, Aug 12, 2012.
  1. Fireman07
    Fireman07 Bobtail Member
    I have an 07 classic with a C-15, my problem is that my air gov. keeps discharging every 3-5 seconds when the engine is boosted but at idle or cruising it will not build pressure. I have replaced the air sep., regulator, and o-rings in the top of the compressor. anyone got a clue of what's going on with it?
  3. Junkyard Johnney
    Junkyard Johnney Light Load Member
    209
    190
    May 27, 2012
    Plains,Mt
    When you say air sep., do you mean the air dryer? If not , mine started this jazz and then quit pumping altogether and it was the air dryer assembly. Somewhere in the cost range of $300, pretty simple to change out, had to do mine on the road but had a basic tool kit made it work.
    The new dryer if it is a Wabco should come with a new cartridge, they are a spin on like an oil filter. Before you do that , check the steel braided line from the compressor to the tank and make sure that it is not ruptured and leaking. Hope this helps...
    J-J
  4. Worthken
    Worthken Light Load Member
    265
    83
    Jun 2, 2012
    Delmas South Africa
    Check the non return on the first air tank. Sometimes it doesnt seat well and it causes the air to shunt.
