Air system problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by labratrans, Jan 20, 2011.
  1. Pumpkin Oval Head
    Pumpkin Oval Head Road Train Member
    1,679
    1,155
    Jun 24, 2010
    Scranton PA
    Are you pulling the same trailer a lot, or do you switch trailers all the time?
  3. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,483
    Oct 18, 2009
    Waynesburg, Pa
    Went through about the same thing not to long ago. It started out that way very slow to build air would even lose air at idle with no apparent leaks. It turned out to be the turbo acctuator (ISX). Only would leak when the truck was running.
  4. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    If you build up the air and release the brakes, then lower the pressure to 50 lbs, it must build up to 90 lbs in 3 minutes. It should do it in 2. You want to remove the compressor discharge line and as was said look and see if it is carbon-ed up. Remove the line from the dryer and see if it is restricted. If it is a Teflon hose it should release if removed and dent. If it is copper then you need to remove it and actually burn it out.
    To test the system for leaks at the unloaders remove the air intake to the compressor and when the compressor is unloaded see if there is air leaking into the intake, depending on what compressor you have you could have a carbon-ed up valve that is not sealing or the plate could be broken.
    Testing a compressor is best done with shop air, and a regulator.
    Just a thought!
  5. labratrans
    labratrans Bobtail Member
    24
    Sep 9, 2010
    Toronto, ON
    Mine is an ISX as well.
    How did you find out ? Did they had to hook up a computer to see what the actuator is doing ?
  6. labratrans
    24
    Sep 9, 2010
    Toronto, ON
  7. Pumpkin Oval Head
    1,679
    1,155
    Jun 24, 2010
    Scranton PA
    I am not an expert, but I would check the following:
    Have you isolated the problem to the tractor or to a trailer?
    Does it do this without a trailer attached?
    Does it do this with every trailer you are hooked up to?
  8. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    water in a tank maybe? sloshing? granted your supposed to bleed your tanks during the pti, but have you?
  9. DL550CAT
    1,427
    1,483
    Oct 18, 2009
    Waynesburg, Pa
    Yes, I ended up taking it to Volvo dealer they found it. They could activate it with the engine off so you could hear the leak.
    labratrans Thanks this.
  10. labratrans
    24
    Sep 9, 2010
    Toronto, ON
    Thanks everybody for your advice
  11. DL550CAT
    1,427
    1,483
    Oct 18, 2009
    Waynesburg, Pa
    Did you find your problem?
