airbags
Discussion in 'Experienced Truckers' Advice' started by starr2000, Sep 26, 2014.
  1. starr2000
    starr2000 Bobtail Member
    6
    I work for a company that is refusing to fix a air brake issue< my air bags are totally depleting when my truck is being loaded, and when I get to work in the morning the air is totally out of the primary 1 tank and tank 2 is sitting at 120 but if I release the emergency brake right away my emergency tank air pressure drops all the way down to match tank 1 in the red..Im also dealing with the brake pressure dropping down to 90 psi when hauling a load when the truck is heavy..the company I work for is the most tyrannical place that i have ever worked for..I definitely need help dealing with the whole situation..
  3. Knucklehead619
    Knucklehead619 Medium Load Member
    547
    624
    Mar 11, 2014
    Flyover Country
    Take your truck to the nearest weigh station or port of entry and let whoever is on duty inspect the truck. If you self report the problem (rather than wait for them to catch you) and let them know your employer knows about the problem, refuses to fix it and is requiring you to drive an unsafe vehicle they should put the truck OOS without any liability on your part. Your employer will then be forced to fix the problem before the truck leaves again. And pay a hefty fine in the process. Your employer may not like it and may fire you but no company should EVER force a driver to knowingly operate an unsafe vehicle.
  4. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    agreed, just make your your DVIR's show the issues every day.
  5. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Have you write this up in pretrip/ post trip inspection report and submit to company (person in charge for safety)?
    If so you have legal rights not to operate this POS equipment and refuse to drive this truck.
    If you don't. Do not go to DOT scale. Driver is solely responsible for equipment to comply with DOT regulatioons and rules before it leaves the yard. If you have drove this truck down to the DOT scale you intentionally operate equipment OOS.
    So write everything in your post/pre trip inspection report and submit. Ask them to underwrite the copy. There could be two responses. 1. Defect fixed and mechanic signature or
    2. Defect is not affect the safety and mechanic signature. If second - go to DOT scale.
    Do not sacrifice your reputation, name or freedom (in worst scenario) to the s...t eaters.
    starr2000 Thanks this.
  6. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Neg. if you drive it on the scale you will be the one getting to sign tic.an paying the fine at coops?
  7. starr2000
    6
    thank you very much for the information its definitely a plus being able to come on truckers report thanks for the help.
  8. starr2000
    6
    I'm definitely putting up a fight..Im finding out that a lot of companies can care less about your safety..thanks
  9. starr2000
    6
    lol..I can't say that the thought hasn't crossed my mind.
  10. starr2000
    6
    thanks for the information very helpful..
  11. Pahrump
    Pahrump Medium Load Member
    quit find an other company to work for,,
