Airline leak
Discussion in 'Ask An Owner Operator' started by HalpinUout, Aug 20, 2017.
  1. HalpinUout
    HalpinUout Road Train Member
    7,074
    18,165
    Oct 2, 2011
    I have a leaking air line that is located under that truck that runs along the frame and it is tied together with a few other lines... The issue is there is no possible way to get my head up into position to see it but I am able to feel it... What are my options as for fixing... I was going to use black electrical tape but was told that's not going to hold.??? Trying to get a clamp of some sort onto it might prove to be difficult....
  3. QuietStorm
    QuietStorm Heavy Load Member
    899
    1,416
    Dec 11, 2016
    Rescue tape. Unbundle it then wrap it and bundle them back up.
    goldwing-rider and HalpinUout Thank this.
  4. Ridgeline
    22,720
    123,220
    Dude, if you are talking about using electrical tape, bring it to the shop and get it fixed right, no excuse being cheap and thinking that it an easy fix.
    Safety first.
  5. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    get a push in style union. cut the line at the leak and put the union in. dot approved and easy-ish to do blind.
  6. HalpinUout
    7,074
    18,165
    Oct 2, 2011
    I'm not sure where I said I was looking to be cheap. Was just looking to do it myself and curious of what others have done. Thanks for the assumption
    bzinger Thanks this.
  7. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    They make a push connector if you can get a clean cut
  8. OLDSKOOLERnWV
    19,114
    289,032
    1st find the leak, determine the size of the line, then get a push in style coupling as mentioned earlier. Some times you have to use the eyes in the ends of your fingers....... to find a leak.
    HalpinUout Thanks this.
  9. AModelCat
    164,543
    Sometimes if you can't get at it you might be better off to pull a new hose through it.
    DDlighttruck, Grubby, Derailed and 2 others Thank this.
  10. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    If the line is leaking it had to be rubbing, push connectors don't always seal good on old tubing.
    tinytim and HalpinUout Thank this.
  11. nax
    nax Road Train Member
    1,999
    2,253
    Dec 14, 2016
    @HalpinUout
    Go to home depot grab this...but only for emergency, not as a complete repair solution
    Dave_in_AZ and HalpinUout Thank this.
