Algae in tanks
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by GliderKitTrucker, May 11, 2020.
  1. GliderKitTrucker
    GliderKitTrucker Light Load Member
    50
    36
    Dec 28, 2019
    What’s the best biocide to clean black algae out of the inside of my tank? And when I do the procedure, I’m just gonna siphon fuel outta the tanks to fill my filters when they need changing, should I just treat one tank at a time?
    A5¢ Thanks this.
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    W hen you get all the bad fuel out of tanks try to clean the inside of both tanks se best you can,if tanks have a plug to drain them you can let the bad junk run on out, If you go by a boat parts shop they have the algae remover in large bottles, try to keep the tanks full as you can so treated fuel will get on top of inside of tanks when you hit your brakes, it can take a few treatments if you cant get as much of it cleaned out while tanks are drained?
  4. Deputy Chief
    Deputy Chief Light Load Member
    81
    40
    Nov 7, 2010
    Philadelphia,Pa.
    A friend of mine used Power Service, it works well. Although he did say, you have to have extra filters at the ready. In his case, He did have the algae pealing loose in clumps, and clogging his filters.
    Rideandrepair and A5¢ Thank this.
  5. GliderKitTrucker
    50
    36
    Dec 28, 2019
  6. AModelCat
    164,548
    I'd drain and clean the tanks out.
    Way I see it, you can dump that algae killer in the tanks and blow hundreds of dollars on fuel filters over the coming weeks. Or you can get the tanks cleaned out, treat the fuel and just have to worry about whatever is left in the lines.
  7. GliderKitTrucker
    50
    36
    Dec 28, 2019
    I don’t have a lift or anything to drain that amount of fuel off. And I don’t wanna take my tanks off. I’ve heard this technique works as well as actually cleaning them. I’ve just never had to do this.
  8. 201
    201 Road Train Member
    12,769
    26,262
    Apr 16, 2014
    high plains colorado
    As long as there aren't any sharks, you're good to go.
    A5¢ Thanks this.
  9. Numb
    Numb Crusty Curmudgeon
    4,310
    10,231
    Jan 30, 2012
    Charlotte, N.Carolina
    avoid Biodiesel
    A5¢ Thanks this.
  10. Studebaker Hawk
    Studebaker Hawk Road Train Member
    3,018
    9,852
    Oct 18, 2010
    NW Indiana
    Make sure you diagnose the problem properly. Many time fuel system problems are blamed on algae, when the problem has similar symptoms, but is treated differently.
    Asphaltine is just like it sounds. Crude oil has all sorts of compounds in it, most but not all are eliminated during the refining process. the leftover sludge of the refining process is what they pave roads with, but some of it is still in your fuel. Under certain circumstances, hot recirculated fuel, combined with bio diesel, combined diesel refined from poor quality crudes can leave deposits in your tank, clogging things up.
    Asphaltene agglomeration leads to the formation of larger and larger clusters and solids, which are very difficult to completely combust. These solids grow so large that they will not pass through the filter element. They become part of the polymer and sludge build up plugging the filter.
    This website has a lot of info diesel fuel, including algae and other contaminants
    https://diesel-fuels.com/real-story-of-bad-diesel-fuel/
    I have used this product to deal with asphaltene:
    Total Diesel Fuel System Cleaner - Penray
    Pen Ray also has other additives to deal with algae.
