Almost a complete disaster
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jeffl0123, Sep 4, 2024.
  1. jeffl0123
    jeffl0123 Light Load Member
    60
    14
    Jan 18, 2018
    So I was not really sure where to put the image but I saved it in Media under truck tire. I will put the link directly to it below. So I need some input what you guys think caused this. So I haul mobile and modular homes. I was hauling a home and felt no issues. There was some plastic ripping on the trailer I was hauling so I pulled into a rest stop on Rt 80 in Milton PA. I got done fixing the plastic and was walking back to my truck and just happened to look at the rear axle and the picture is what I saw. There were 3 studs left with only 2 that had lug nuts on them. I immediately thought about how close I was to a disaster cause I only have a single rear axle truck. 2000 FLD120. So about 2 weeks ago a shop swapped out a 20,000lb rear for a 23. Since getting it back I probably put about 1200 miles on it. I immediately called the guy and said did you tighten these lugs? Then I told him what was going on. At first he did not say anything. Got off the phone and he called back and then said he would pay for new rims, studs and lugs. He also said that he watched his guy use a torque wrench and tighten the drivers side. This happened on the passenger side. But I then said I can't see that because I also checked the drivers side and I could turn 3 of the lug nuts with my fingers. So my question is whats your take on it. I myself have had these tires on and off many times and never had an issue, with any truck for that matter. He is insisting he tightened them but I call BS. What do you guys think?
    https://www.thetruckersreport.com/truckingindustryforum/media/truck-tire.22277/
  3. MRMTRANS
    MRMTRANS Medium Load Member
    407
    440
    Apr 28, 2015
    He didn't have correct torque on them. It's irrefutable.
  4. PaulMinternational
    PaulMinternational Road Train Member
    1,108
    5,831
    Aug 23, 2022
    I would also claim Bull S on his claim of watching the guy use a torque wrench. Even when the torque wrench is out of spec they are rarely ever out far enough to have this happen.
    Be thankful he is willing to pay for the damage and that you caught it before it became a disaster.
    Flat Earth Trucker and The_vett Thank this.
  5. Chinatown
    Chinatown Road Train Member
    77,660
    184,027
    Aug 28, 2011
    Henderson, NV & Orient
    Torque wrenches have test dates and the shop owner should have a record of that, but my bet is he doesn't.
    Let him pay like he said he would and move on.
  6. MRMTRANS
    407
    440
    Apr 28, 2015
    Truckstop shops have written on the receipt that wheels should be retorqued after 100 miles. I've always believed that's to cover their liability in case the mechanic didn't torque correctly. I never retorqued and never had a problem.
  7. SmallPackage
    5,777
    18,536
    Dec 20, 2019
    Marion Texas
    Could be studs were previously stretched from over torque.
    Mounting surface of assembly had crud on it somewhere causing bad seating issues.
    Wheel was not seated correctly over hub. Common with this new design.
    Lug nuts where not replaced with new ones when put one.
    Torque spec on them are 500 ftlbs. And nuts are are supposed to be replaced after a couple uses.
    Wheel offs with hub center style wheels has been astronomical. Studs are two small for two wheels. They are hard to seat and the nuts do very little clamping when the wheels just float around the studs. Torque needs to be checked more frequently but never is.
    austinmike Thanks this.
  8. xsetra
    xsetra Road Train Member
    5,195
    7,146
    Aug 21, 2011
    It is possible the shop torqued the nuts. When they check with torque wrench, if the nuts don't move with torque wrench. How tight are the nuts?
    The nuts could have been over tightened, stretching the bolts.
    Chinatown Thanks this.
  9. MRMTRANS
    407
    440
    Apr 28, 2015
    Years ago, I know someone who had wheels under torqued and and a wheel came off around 1k miles later. All other positions were undertorqhed as well. I have a hard time believing stretched threads and/or improper seating because of corrosion on hub face and/or wheels a wheel wouldn't stay on more than 12k miles if torqued right. I've done my own tires for 20 years and have let slide corrosion when in a hurry. I would fix tires in a parking lot using air from the truck and wouldn't spend time chasing threads and cleaning hub face.
    The_vett and austinmike Thank this.
  10. xsetra
    5,195
    7,146
    Aug 21, 2011
  11. SmallPackage
    5,777
    18,536
    Dec 20, 2019
    Marion Texas
    When a wheel comes off and causes an accident one of the first things an investigator looks at is the amount of corrosion on the hubs. They then will check for damaged studs. Stretched, bent, out of round, and flattened threads. Industry rule of thumb says if two or more studs fail it is due to over stretching. This is why they highly recommend replacing the studs and nuts on both sides of a bad one even if they look good.
    austinmike and Concorde Thank this.
