Almost made a bad mistake...
Discussion in 'Experienced Truckers' Advice' started by Voyager1968, Jan 14, 2013.
  1. Voyager1968
    Voyager1968 Road Train Member
    2,378
    2,904
    Sep 11, 2008
    ...and I should have known better. Things have been slow where I work right now due to something at our dedicated customer that no one can seem to explain. We, as drivers, think they either lost a lot of accounts, or they are moving production elsewhere. Anyway, our hours and loads have been cut drastically, so I began to look for a new company to drive for.
    So, not far from me is a small company that runs regional. They are very close to the house, so I apply. Very nice people, and they tell me that they run out and back from their customers and the drivers are home every other night, or at the most, out 2 nights. Again, sounds good. They run older pre-egr equipment that on the outside looks nice. I fill out an app, and am subsequently hired, and am sent for a pee test. All still seems good.
    Then, and this is where I am at fault, as I didn't do the research BEFORE applying for the job, checked out their safety stats. As it turns out they are pretty bad. Their HOS Compliance exceeds the federal threshold, sitting at 90.7%, and their vehicle maintenance is close to exceeding the threshold at 69%. Over half of their roadside inspections produced some kind of violation, and over half of THOSE violations were serious enough to place the truck and/or driver out of service.
    For anyone that doesn't understand, those percentage numbers indicate that that percentage of companies has a BETTER rating then the one indicated. To me, the 90.7% on the HOS tells me that they either allow or require that a driver routinely violate the regs in order do deliver freight on time. Either way, I don't plan to work for this company, and now have to call them and tell them I'm not interested in driving for them.
    Moral of the story for any of the newer drivers out there. Make sure you exercise "due diligence" and check out the company before you apply and interview. They may not be what you thought they'd be. With 14 years experience, I should have known better. I'm just glad I found it out prior to actually getting behind the wheel and working for these people.
    For anyone who doesn't know where to start, here is a link...
    http://ai.fmcsa.dot.gov/sms/
    double_r, scottied67, chalupa and 18 others Thank this.
  3. LeadfootSlider
    LeadfootSlider <strong>Queen of the Confused</strong>
    170
    39
    Jul 15, 2006
    Crystal Spring, PA
    Excellent advice for everyone. Glad you dodged that bullet.
  4. Chinatown
    Chinatown Road Train Member
    77,614
    183,713
    Aug 28, 2011
    Henderson, NV & Orient
    How much money could you make there?
  5. trknfool
    trknfool Bobtail Member
    40
    48
    Jan 7, 2013
    Ludlow Falls Ohio
    Keeping an eye on the CSA score of any company you are thinking of working for is a good idea. A score over the threshold in any category can cause you to be stopped for a DOT inspection. When a carrier goes over the threshold it flags that company in the DOT’s computers and causes you to have a greater chance of getting stopped for an inspection.
    PICNIC and Pound Puppy Thank this.
  6. 900,000-tons-of-steel
    900,000-tons-of-steel Road Train Member
    1,511
    896
    Aug 17, 2012
    Florida
    Where is the threshold information listed on that site?
  7. fisher guy
    fisher guy Road Train Member
    1,993
    1,061
    Mar 22, 2009
    Ocala Florida
    this is a very good site i found just last night all u need to do is type the carrier name or dot # in the search box and poof it will guide u right the where u need to go on the fmcsa/csa website http://www.whatiscsa.com/search/index.xhtml
    on a side note i know my company's csa is thru the roof and i knew that going in all reality they are doing everything they can to get that number down i believe they fired 5 different drivers for too many violations last week and considering we only have 38 trucks thats saying something. maintence is by far the best i've seen then with any company i've worked with and log books they give u the tools u need "to do what u gotta do" but by no means do they make u do it or expect u to do it we got guys that run legal and make good money and we got guys that run illegal and know how to hide it so it doesnt get caught in an audit or roadside and they make great money.
    so the moral is dont believe that csa scoring thing 100% like the op said use "due dilligence" when choosing a company look at there trucks and i dont mean look from a distance i mean do a full pretrip on them. hows the brakes,tires looking are they nasty and greasy under the hood that kinda stuff .
    sometimes companies get some crappy drivers and some bad luck and they want to get better because what company do u know that wants to get shut down perminatly
    UTI TRANSPORT Thanks this.
  8. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    Yeah it doesn't hurt to check on the scores. But don't let the FMCSA fool you into thinking that they are on top of every company that's at the threshold because they are not. If everything else looks like a good fit, and you aren't making any money at your current job, I would still consider the high CSA place.
    Chinatown Thanks this.
  9. 900,000-tons-of-steel
    1,511
    896
    Aug 17, 2012
    Florida
    Can't locate the thresholds on that link, either.
  10. Ghost Ryder
    Ghost Ryder Road Train Member
    1,647
    1,182
    Jan 3, 2013
    Your Mailbox
    So you take the job and the DOT shuts the place down, and then you're back to square 1. Broke and no job.
  11. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    I think threshold is 70%
    900,000-tons-of-steel Thanks this.
