Alternator charging
Discussion in 'Ask An Owner Operator' started by TruckerOnDuty13, Feb 9, 2024.
  1. TruckerOnDuty13
    TruckerOnDuty13 Bobtail Member
    33
    8
    May 27, 2023
    Hi,
    not sure if i posted in right forum before or even now but on Cummins x15, Just curious how long will an alternator take to charge 4 cat batteries from absolutely low voltage. I jumped it once and ran truck, idle 15mins and highway 25mins. Dash showed 13.1v with lights off. However, 15 mins later auto kill switch kicked in meaning the charge dropped. Batteries and alternator was replaced 4months ago. Any feedback or do i need to run the truck longer? I hear some people say 30mins enough and some online say upto 24 hours. Not sure and confused.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    30 mins probably enough to start it again warm, a few hours to have enough to start cold. 13.1 not enough, alternator should be closer to 14.2 volts. Likely has blown diodes.
    Rideandrepair Thanks this.
  4. TruckerOnDuty13
    33
    8
    May 27, 2023
    Yes usually it sits around 13.8-14.1. I drive city whats the best way to get them charged? Once it touches 14 means im good?
  5. snowwy
    snowwy Road Train Member
    20,611
    13,326
    Jul 6, 2009
    The alternator is probably 150 amps.
    Someone else might know the exact answer.
    The batteries are close to 1000 amps. X4 and that's close to 4000 amps.
    So how long would it take 150 amps to charge 4000 amps?
    When the truck is off..there's a parasitic draw for the electronics. It's not much. But if the truck is dead. Runs for 15 minutes. It'll probably be dead again after 24 hours.
    It usually takes a full day to charge em back up.
    But you have a problem. Low voltage alarm and truck shut down. If the alternator were working. You wouldn't have that problem.
    A good alternator will be able to run all accessories and still have .5 volts left to charge the batteries. That's 13.1 volts minimum with everything turned on. You had 13.1 volts with everything off.
    Dead batteries usually start with 13.5 and climbs as the batteries charge up. To 14ish.
    Doesn't sound like your alternator is working.
  6. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    I jumped a dead truck the other day. 10volts and zero % charged on battery monitoring. Took 15 hours at idle with nothing on to charge 4 group 31’s to 80% state of charge.
  7. Ridgeline
    22,721
    122,970
    If you want to charge the batteries a little faster, don't idle, bump the engine up to 1100 rpm.
  8. uncleal13
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    No, 14 volts just means the alternator is now working at normal output. The only way to tell from the dash would be if the truck had an amp meter, I’ve only ever had one truck that had one. It would show 100+ amps while charging and then it would slowly lower to 10 or 20 amps once the batteries caught up.
  9. xsetra
    xsetra Road Train Member
    5,195
    7,146
    Aug 21, 2011
    Why did you change batteries and alternator 4 months ago? Was it the same reason as now?
    Check all your battery cables including those to your alternator.
    If your truck is shutting down while it is running either your alternator isn't charging, your batteries won't accept a charge or a short in the system. Could be 1 of your batteries is bad. My alternator sits at 14.1 all the time. Low idle or running at 70 mph.
    Get a different source to charge your batteries. When fully charged disconnect all the cables. Check each battery for a full charge. IF all four aren't fully charged you have a bad cable or bad battery. IF all 4 batteries are charged, leave disconnected, and check for charge again an hour or so later. See if any lost power. IF they check out ok. IT is your alternator not charging. Or you have a cable issue. Could be a short in the system.
    Get one of these.
    good luck
    How long has your charging system been acting like this?[​IMG]
