Alternator over charge
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Wvcoalpacker, Nov 19, 2019.
  1. Wvcoalpacker
    Wvcoalpacker Bobtail Member
    23
    8
    Dec 22, 2017
    I have a 09 389 peterbilt that I put a c15 in about a year ago and everything has been fine until now. Starting a couple of weeks ago every time it rains it starts over charging. It has cooked 2 batteries so far. I’ve changed the alternator twice and all the cables from and to the batteries and the starter.. even put an extra ground to the alternator. I switched all 3 batteries out with another truck I have and still same. I am at my wits end.. can anybody please help?
  3. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Gauge issue? Have you put a quality meter on it to confirm it actually is overcharging? What brand are you using for replacment alternator? Have you tried a different brand or the same?
    Wvcoalpacker Thanks this.
  4. Wvcoalpacker
    23
    8
    Dec 22, 2017
    I’ll have to check and see what brand of alternator it is.. I just usually take whatever brand my local peterbilt store sends me. I have put a multimeter on it to confirm it and the gauge is right. It goes up to around 15.7 and after a few minutes in the dry it goes down to 14.5 at the batteries and 14.6 at the alternator.
    KB3MMX Thanks this.
  5. AModelCat
    164,520
    Does the alternator have an external regulator or a voltage sensing wire? I'd be inspecting those.
    KB3MMX and Wvcoalpacker Thank this.
  6. Wvcoalpacker
    23
    8
    Dec 22, 2017
  7. Wvcoalpacker
    23
    8
    Dec 22, 2017
    I don’t have the voltage sensor wire but it’s never had that wire. I have always thought it wouldn’t go over 14.5 anyway.
    I’ll try putting a wire on it and see what that does. It just goes from batteries back to alternator right?
    KB3MMX Thanks this.
  8. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    Double check the cables connecting your batteries. Can have one go bad and the alt is trying to compensate for what it thinks is a dead battery.
  9. Wvcoalpacker
    23
    8
    Dec 22, 2017
    I changed all cables even the jumpers from battery to battery.
  10. Wvcoalpacker
    23
    8
    Dec 22, 2017
    Well I guess you were right, I ran a wire from the batteries to the bottom post on the alternator and it's charging at 14.1 and I've sprayed it with the garden hose and it doesn't change. Thank you !
    KB3MMX, Goodysnap and AModelCat Thank this.
  11. Mike250rs
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    nevermind.. op fixed it
