Alternator vuage.
Discussion in 'Peterbilt Forum' started by Bernard D, Oct 17, 2020.
  1. Bernard D
    Bernard D Heavy Haul Member
    104
    27
    Jun 27, 2020
    03,pete,379 ,c15
    Everything works great but when i start it up all the guages work fine but i have to rev it up and then tbe,Alternator guage works.
    Stays working untill i turn it off for awhile and same thing.
    Any ideas would help.
  3. SmallPackage
    5,701
    18,220
    Dec 20, 2019
    Marion Texas
    Amp gauge or Volt gauge?
    Could be 2 things that have the same symptoms.
    Amp gauges are sometimes finicky and won’t cut in and register till engine revs up a bit off idle rpm. Depending on how Volt gauge is wired thru key or not it may read battery power full time with key off or only when key is on. They get lazy sometimes and rise slowly.
    If alternator is slow to cut in or needs a slight rise in rpm to begin charging which is pretty normal with age there may not be anything wrong with gauges at all.
    Lazy gauges or lazy when cold alternator= same symptoms with gauges but not necessarily anything that needs fixing if everything is charging and keeping batteries happy.
    spsauerland and Bernard D Thank this.
  4. Bernard D
    104
    27
    Jun 27, 2020
    Thanke you very much.
