Am I exempt from the ELD mandate
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by jlk, Jan 7, 2018.
  1. jlk
    jlk Bobtail Member
    6
    Dec 29, 2017
    I have a 2012 Coronado Glider with a d deck 3 engine. Is this truck exempt?
  3. easytopleez33
    easytopleez33 Light Load Member
    251
    325
    Jan 6, 2015
    I may be mistaken. But, from what I've been told, regardless of the year of the truck. In your case and many others a newer Glider. Powered by a pre-2000 manufactured engine is considered exempt, in accordance to the ELOG Mandate. There are about three exemptions and that was one of them,
    That being said, it wouldn't hurt to get a document from Detroit Diesel specifying this to be the case.
    Hope this was somewhat helpful
  4. jlk
    jlk Bobtail Member
    6
    Dec 29, 2017
    Thanks, that’s what I’ve heard. Just wanted to confirm. Just having a hard time finding it actually written down somewhere.
  5. easytopleez33
    251
    325
    Jan 6, 2015
    I think if you go onto JJ kellers site you can upload the ELOG exemptions. And the document from Detroit is for the Ports and Scales who will invariably look high and low to make sure your not trying to pull a fast one.
    I've got a buddy who"s a BullHauler that specced his Glider with an 3406-E model cat just for this reason.
    Personally I see everyone on ELOGS eventually. But, hey, doesn't hurt to try I guess.
    jlk Thanks this.
  6. TankerYankerD001
    TankerYankerD001 Light Load Member
    68
    40
    Dec 19, 2017
    Baltimore MD
    They are going by the engine year now it was the truck it self before.
    easytopleez33 and jlk Thank this.
  7. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Google - FMCSA and what you are looking for..
    If the vehicle registration for a commercial motor vehicle reflect a model year of 2000 or newer, bu
    If the vehicle registration for a commercial motor vehicle reflect a model year of 2000 or newer, but the engine plate or documentation from the manufacturer indicates that the engine is older than model year 2000, is the vehicle exempt from the ELD rule?
    Yes. While an ELD may voluntarily be used in vehicles that are model year 1999 or older, use of an ELD is not required in these vehicles; likewise, vehicles with engines predating model year 2000 are to be treated as exempt, even if the VIN number reported on the registration indicates that the CMV is a later model year. When a vehicle is registered, the model year should follow the criteria established by the National Highway Traffic Safety Administration (NHTSA). There may be instances where the model year reflected on the vehicle registration is not the same as the engine model year, most commonly when a vehicle is rebuilt using a “glider kit.” In this circumstance, an inspector/investigator should use the model year on the engine to determine if the driver is exempt from the ELD requirements. If the engine model year is older than 2000, the driver is not subject to the ELD rule. While the driver is not required to possess documentation that confirms the vehicle engine model year, 49 CFR Part 379 Appendix A requires motor carriers to maintain all documentation on motor and engine changes at the principle place of business. If a determination cannot be made at the roadside, safety official should refer the case for further investigation.
    TallJoe and easytopleez33 Thank this.
  8. TA1199
    TA1199 Light Load Member
    114
    78
    Sep 12, 2015
    Staten Island, NY
    Yea, that's what got me all screwed up. Very easy to tell if you have a pre-2000 motor. Look at the vin. number. If there is an X in it then it is a pre-year 2000 motor. If there is a 0 it is 2000 or newer. I thought I had a pre-2000 motor because my build date was in 1999. Depending on what time of year the truck was build depended if it had a 1999 engine or, 2000 engine.
  9. DUNE-T
    DUNE-T Road Train Member
    7,044
    17,158
    May 10, 2015
    Detroit, MI
    ??? The VIN indicates the year vehicle was built, but it has nothing to do with the year engine was manufactured.
    easytopleez33 Thanks this.
  10. TA1199
    114
    78
    Sep 12, 2015
    Staten Island, NY
    Right, what would I know it's not like it just didn't happen to me or anything like that.
  11. DUNE-T
    7,044
    17,158
    May 10, 2015
    Detroit, MI
    Sorry, have no idea what you just said. Can you rephrase it?
