An Idle Question
Discussion in 'Experienced Truckers' Advice' started by ShallowDOF, Nov 20, 2012.
  1. ShallowDOF
    ShallowDOF Light Load Member
    195
    110
    Feb 18, 2008
    Kenmore, WA
    When idling with the cruise on and set, does the engine respond to the throttle?
    If you could include the year, make, model and engine in your truck in your answer, that'd be awesome.
    Im working on a project and this info will be very helpful. (and has the potential of benefitting you.
    Also, can a mod/admin PM me?
  3. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    Mine doesn't. It's a 2011 Volvo VNL780 with a non DEF Cummins ISX 450 ST
  4. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    2012 Cascadia (Automatic) with DD15
    The Truck will Idle all day, but it doesn't allow me to set cruise.
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    2009 kw w900L, cat motor, it will set cruise at idle to whatever rpm you want. If you push on the fuel it will increase fuel and when you let off it will continue at whatever rpm cruise is set to. Hit brake or clutch and it cancels cruise as normal.
  6. CAXPT
    CAXPT Road Train Member
    3,329
    15,560
    Feb 10, 2008
    Some trucks use the cruise control as a limited speed control mechanism...hit it up, and it idles up, down and it idles down. Staying minimum at the idle rpm.
    I think that's how the 2000 KW 900 worked and a 2009 Freightliner.
  7. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    ditto 95' ddec 3
  8. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Ditto - 2008 T660 with C15.
  9. twolane
    twolane Medium Load Member
    468
    252
    Dec 16, 2010
    Arizona
    Ditto- 2004 Ftl. Century, Detroit series 60
  10. FatDaddy
    FatDaddy Road Train Member
    4,314
    10,375
    Dec 23, 2008
    Katy, TX or Swedesboro, NJ
    Ditto, 07 ftl century, detroit 60
  11. snowwy
    snowwy Road Train Member
    20,609
    13,323
    Jul 6, 2009
    05 w9 isx 450. i could set the idle with cruise. i could also change the idle without cruise. per computer. if the cruise was off. i could adjust my constant idle. sorta like adjusting a carburetor. with the cruise on. i could change the rpms. flipped the switch off and idle came back.
    however. i could not give it gas if i had the cruise on for idle. release the brake and attempt to drive was a no go till the cruise was deactivated. i've found myself pushing the gas pedal with no acceleration quite a few times. LOL.
