Another Thermo king APU question!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Tuzla075, Nov 11, 2013.
  1. Tuzla075
    Tuzla075 Light Load Member
    60
    17
    Dec 4, 2012
    Anyone had a problem with your TK APU user interface when there is no power to it?
    I just tried to press ON button, but there is no power, I will check the fuses tomorrow, and see, since I am at the truck stop and its snowing:biggrin_25512:
    If anyone already encountered this problem, what have you done to it to get it to work! And maybe u know already which fuse is to be replaced!
    Thanks!
  3. bjytech
    bjytech Light Load Member
    246
    222
    Nov 9, 2013
    I've worked on several APU's with this problem and for me its always turned out to be either a main power wire on the APU alternator corroded off, or the fuse holder for the big 50amp fuse thats tucked up in the back of the APU above the alternator will get corroded up to the point where it loses contact.
    Tuzla075 Thanks this.
  4. indspirit
    indspirit Light Load Member
    147
    131
    Aug 17, 2013
    Yes has been the same for me. Also they have a lubricant you can get to help reduce the corrosion it us inexpensive and does help
  5. Minder Kat
    Minder Kat Light Load Member
    77
    48
    Jul 4, 2012
    Brush, CO
    My previous TK APU problems, including the interface, were because of the single earth connection at the bottom of the APU. It corroded from the salt on the roads and caused a myriad of issues. I had all the terminals on the earth wires replaced, soldered up and I added a plastic coating to prevent future issues.
    On a different occasion I had to replace the fuse, wire and terminal between the under-bunk control box and the battery. It was corroded too.
  6. TZ075
    TZ075 Bobtail Member
    7
    Chicago
