Another tuning question
Discussion in 'CB Radio Forum' started by BluBeaSSt, Jul 24, 2014.
  1. BluBeaSSt
    BluBeaSSt Light Load Member
    96
    20
    May 2, 2012
    Kansas City MO
    Okay so I'm pretty new to radios. I have a Stock Cobra 29LTD, with a Wilson 5000 Antenna, and about 20 feet of coax.
    My SWRs are high (about 5 on Ch1, about 6 on 20 and 40).
    So my question is do I need to cut the antenna whip or extend it to lower my SWRs?
  3. KAK
    KAK Medium Load Member
    518
    2,073
    Feb 10, 2012
    Ne
    Do NOT cut anything yet. If you are at 1.5 and 1.6 you are close. IF it truly is 5 and 6 you have some big time grounding issues and no amount of cutting will help
  4. BluBeaSSt
    96
    20
    May 2, 2012
    Kansas City MO
    It's on a Volvo and they have those #### powder coated mirrors. I'll take the mount off and grind more of the powder coating off first then.
  5. KAK
    518
    2,073
    Feb 10, 2012
    Ne
    Yup, I don't know much but ya need to get it way down, probably closer to 2 before cutting. Hopefully someone with more knowledge will chime in. Just tryin to keep ya from ruining a whip right away.
  6. BluBeaSSt
    96
    20
    May 2, 2012
    Kansas City MO
  7. BluBeaSSt
    96
    20
    May 2, 2012
    Kansas City MO
    I'm half ### retarded, I just got fuel and checked it again. 1/20/40 they are just above 3 on the SWR meter.
  8. mike5511
    mike5511 Road Train Member
    3,155
    1,546
    May 15, 2011
    NW Arkansas
    Still a grounding problem. And it is probably rf ground and not electrical ground. You may have to do some bonding to get it where it needs to be. Braided bonding straps are best. You can use coax (has a braid in it.) Run short runs instead of one long wire. i.e. antenna mount to door, door to body, body to frame. Sometimes it can be a real challenge and same model trucks can be totally different.
  9. Powder Joints
    7,967
    8,335
    Sep 25, 2007
    Rosamond, SoCal
    My guess is that the problem is your antenna cable, maybe shorted or open. Use a ohm meter and check your end to end making sure that the enter conductor and the shield are continuous, but not shorting to each other, if that's good check the pl259 to make sure it is soldered properly.
    This needs to be confirmed before your needing to get into adding grounds. ground loops cause a whole new set of problems.
  10. Xcis
    Xcis Medium Load Member
    498
    270
    Jul 9, 2008
    Bridgeport, Pa
    Listen to Mike5511 because he nailed it. Anytime your SWR reading on an external meter is 3 or higher, you should be thinking bad antenna ground plane.
    .What you need to do is interconnect the large metal components of the truck for RF [radio frequency] purposes into one large antenna ground plane. Run short lengths of braided ground straps. First, from the antenna mount to the door. Next, A separate strap from a bolt that mounts the door to the hinge. The other end of the ground strap goes to the bolt that mounts the door hinge to the cab frame. Finally, from the cab frame to the chassis frame.
    .As Mike correctly stated, keep all straps short in length. Otherwise, a long strap could act as another antenna. Which is exactly why running a strap from the antenna mount directly to the battery is a bad idea.
    HighCountry Thanks this.
  11. hayseed
    hayseed Light Load Member
    211
    109
    Dec 31, 2011
    The Natural State
    Mike has a good teacher..................:biggrin_25514:
