Antenna question
Discussion in 'CB Radio Forum' started by TriAxleTrucker16, Dec 10, 2008.
  1. TriAxleTrucker16
    TriAxleTrucker16 Light Load Member
    107
    17
    Dec 9, 2008
    South Carolina
    So I bought the Galaxy DX919 and a triple-coil firestik. The SWR switch on the radio, when switched on, reads about 1.2, is that pretty good for me setting it or should I take it to a shop?
  3. BOOTYMONSTER
    BOOTYMONSTER Light Load Member
    99
    64
    Oct 3, 2008
    RICHMOND VA.
    id at least check it against an external meter , theyre more accurate .
    1.2 is a very good vswr .
    anything 1.5 or less is good for use with an amp .
    2.0 or less for a barefoot radio is supposed to be fine .
    i tune as low as i can .
  4. Big "A"
    Big "A" Light Load Member
    72
    12
    Nov 29, 2007
    White Bluff,Tn
    Thats good lower the better, did't want it over 1.5 and some times the meter on some radios ant worth a s*** so u might carry it too a cb shop and get them to put there meter on it.
  5. TriAxleTrucker16
    107
    17
    Dec 9, 2008
    South Carolina
    I appreciate the info, gonna get a meter sometime this week, Thanks guys
  6. Brickhauler
    Brickhauler Medium Load Member
    411
    142
    Oct 1, 2008
    Elizabeth CO
    To get the best reading, check SWR on ch 1 and 40 and tune antenna to be the same on both channels. This will give you the lowest SWR over all channels.
  7. Hamster
    Hamster Bobtail Member
    35
    4
    Dec 15, 2008
    Germany
    Or tune the radio to the middle of the band (Channel 19 / 20) for the best SWR.
    BTW, I don't know this antenna, but you said that it contains coils?
    Coils are usually used for mechanically shortening the antenna, while making the transmitter believe that there is a full size 1/4 wavelength (about 6 3/4 feet for the 11 meter band) antenna connected. These coils reduce the efficiency of the antenna.
    If it is mechanically possible, I'd use a fullsize antenna mounted in the middle of a flat metal cab roof.
    Jan
