Antenna warning
Discussion in 'CB Radio Forum' started by Logan Spoo, Aug 6, 2018.
  1. Logan Spoo
    Logan Spoo Bobtail Member
    7
    Jun 14, 2015
    I replaced my Wilson 2000 antenna 5” shaft with a new Wilson 2000 with 10” shaft and new coax cable I recalibrated and read swr with no cutting swr was 1.5 across the board. If I transmit on ch. 1-20 no antenna warning but ch 20-40 the red ant warning lights up. Is this just a case where I need to cut some? I’m on ch 40 90% of the time
  3. #wishfulthinking
    #wishfulthinking Light Load Member
    203
    551
    Jun 9, 2018
    Central Iowa
    What is your SWR reading on ch 40? What kind of radio is it? If it's a Cobra then it sounds like it's too high. If that's the case, you will need a trim. Before you do that though (If it has an SWR switch on the radio) make sure the SWR switch is in the right position and double check the SWR on ch 1, ch 20 & ch 40. I'm not insulting your intelligence here, it's just easy thing to overlook and it's been done many times before.
  4. Diesel Dave
    9,645
    32,594
    Jan 20, 2010
    Hesperia, Ca.
    When I replaced my short shaft to an 18” shaft, I didn’t replace the coil. I had to cut the stinger quite a bit to get the SWR back down. Mine is a 2000 also and has it more than 20 yrs, even longer.
  5. Logan Spoo
    7
    Jun 14, 2015
    Yes it's a 29 Ltd a
    Classic. I will recheck swr and probably will trim some thanks for the advice guys!
  6. Diesel Dave
    9,645
    32,594
    Jan 20, 2010
    Hesperia, Ca.
    You have to use one of those antenna analyzers. The one on the radio isn’t good enough. I reliable radio shop should charge from 15-20 to get it on the money.
  7. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    I wouldn’t trim your antenna, until you get a good external meter on it, to see what the swr really is. I have been driving our companies t800 last week, and it has a brand new cobra 29 LX in it. Its fairly quiet at times. The internal meter in the radio shows SWR at 1.2. I brought my antenna analyzer from home and it showed a 5.1 for swr. Just shows you can’t trust the internal swr meter on those cobra radios. Also, those swr warning lights can be kind of flaky too.
    Oxbow and Diesel Dave Thank this.
  8. Ridgeline
    22,720
    123,248
    BEFORE you do a thing, get an external SWR meter and figure out what the SWR really is. If you can't go to a shop that can do it and tell you what is wrong.
  9. Expeditor
    Expeditor Medium Load Member
    451
    530
    Mar 5, 2018
  10. Ridgeline
    22,720
    123,248
    Yeah there is one but I doubt the OP has a 25 ohm resistor and a 1kc audio source to set it with.
  11. Expeditor
    451
    530
    Mar 5, 2018
    No audio source or resistor needed. Right from Cobra. Won't hurt the radio.
