Antifreeze
Discussion in 'Experienced Truckers' Advice' started by Canon Beach, Feb 15, 2019.
  1. Canon Beach
    Canon Beach Bobtail Member
    5
    Dec 26, 2018
    So, I lost a water pump belt last week. Engine got hot and lost a bit of coolant. Stopped overnight at a convenience store truck stop and bought some what I thought was red but maybe was orange anti-freeze concentrate and topped it off. Guy I'm working for is freaking out. What did I do? Anti-freeze I topped off with was Carquest dex-cool compatible. DD15 engine. Thanks in advance!!
  3. Snakeschasingcars
    Snakeschasingcars Heavy Load Member
    743
    1,570
    Mar 22, 2018
    Dont mix the colors. It tirns to sludge
    flood Thanks this.
  4. austinmike
    135,722
    I wouldnt worry about it. Ive put whatever color was available in trucks. they are still running.
    Grubby and Canon Beach Thank this.
  5. Rideandrepair
    17,532
    56,814
    Aug 8, 2015
    It probably had decent cool already. Should be fine.
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Drain it out. Okay in a pinch, but will cause problems later if left in.
    Canon Beach Thanks this.
  7. Canon Beach
    5
    Dec 26, 2018
    Right on!! Thanks for the replies. Did a bit of further internet research and the consensus seems to be no big deal, just get a flush in the next couple of weeks and put in the OEM stuff and carry on!!! Thanks!!
    austinmike Thanks this.
  8. Rideandrepair
    17,532
    56,814
    Aug 8, 2015
    If you had red AF already, that’s dex -cool. No need to worry. Won’t hurt to flush, but not necessary if you added compatible A/F. Mixing red with green causes problems. Originally dex-cool was made by Texaco, I had it turn to jello after sitting for 3 months. Since then there’s been class action lawsuits against GM. I Recently switched back to “ Final Charge”. Seems the original problems with red A/F have been resolved. A/F like oil never goes bad only the additives get depleted or A/F gets contaminated
