Antifreezing dump bed
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Kw900a, Jan 18, 2015.
  1. Kw900a
    Kw900a Light Load Member
    55
    13
    Sep 29, 2011
    mifflinburg pa
    Ok i been searching all weekend. I have yet to find an true answer. I run a dump trailer haul dry coal wet coal b scrap glass basically anything. So my ? Is what do you guys use to treat your beds i head antifreeze,diesel,oil,magflakes. I can see where All these can hell but what do you guys use. I was just wondering im thinking using a sprayer would be best vs spreading mag flakes all over. Thanks for the help
  3. Badcable
    Badcable Medium Load Member
    356
    191
    Feb 1, 2008
    Outside Chicago, IL
    Most of the dump guys around me carry a garden sprayer with diesel to keep things moving.
  4. Allow Me.
    10,760
    12,545
    May 28, 2009
    Rancho Mirage, Ca.
    ^^^ yeah we use that in asphalt also.
    Voyager1968 Thanks this.
  5. mitchtazz
    mitchtazz Road Train Member
    1,826
    503
    Sep 6, 2009
    Lake Wales, Fl
    coolant, salt, or calcium. the product dictates.. scrap metal like zorba, i can use pretty much anything. but somethings can't mix. I've never used diesel, we switch products too often and i'm pretty sure it'll have to be washed out afterwards.
  6. 201
    201 Road Train Member
    12,722
    26,165
    Apr 16, 2014
    high plains colorado
    Hi Allow Me, don't let the man (or woman) catch you spraying diesel in your dump box. I hauled "schluck" for a while, and we had to switch to those soap suds, which didn't work too well. Some of the old timers still used fuel oil, but today fines can cost you plenty, if caught, that is.
  7. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    Not diesel, EFRA - Environmentally Friendly Release Agent, aka Diesel!
  8. Kw900a
    55
    13
    Sep 29, 2011
    mifflinburg pa
    I was kind of ruling out diesel i was leaning more toawrds oil or antifreeze or maybe calcium chloride. I mean b scrap wont matter if you use oil or antifreese. Boss is one who said antifreeze would work but id imagine itd freeze depending how much moisture/ water is in it. Hes switching. All his trucks to red so we have alot of green. So hes not 1 with a frozen load. Im just trying to look for something that will keep material with moisture from sticking.
  9. Mattnatti
    Mattnatti Light Load Member
    239
    176
    Jul 10, 2014
    Cincinnati, Ohio
    I haul aggregate 99% of the time. Off road fuel and hydraulic oil mix is what I use. Seems to work better than just fuel.
    I don't haul OTR but I don't like aggravating my shoulder by shoveling out the bed. Spray it down at the end of the day and carry a sprayer loaded for a spray down mid day if necessary.
    Semi is is right though, a diesel bear won't like you using fuel. Another driver that hauls OTR said his company uses liquid calcium.
  10. Nicknice
    Nicknice Light Load Member
    66
    39
    May 10, 2014
    I run dump truck and use a 10 sprayer from walmart and diesel.... works better than anything I seen so far
  11. poppapump1332
    poppapump1332 Road Train Member
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    Use calcium works great its what ive been using this winter in my frameless.one scoop of calcium to one gallon of hot water shake up and all set.
