Any idea whats up??
Discussion in 'Freightliner Forum' started by slowmotionZ, Jul 17, 2015.
  1. slowmotionZ
    slowmotionZ Bobtail Member
    I have a 2013 freightlineraforementioned about a month I have been burning through .On average a gallon of oil every 12-1300 miles and solid yellow checkengine light came on twice in the past two weeks. Shop says they found no leaks internal or external. And last time the engine light was on it was just in need of a forced regeneration. Any ideas before I take it back in???
  3. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    how many miles are on your truck? could be just rings setting up. far as the CEL light, i cant help
  4. slowmotionZ
  5. damutt
    1,126
    370
    May 6, 2013
    rings should all be set by now. leaking any oild from outside the block? dipsitck were it connects to pan? drain plug?
  6. slowmotionZ
    Not even a small leak. I got the codes pulled for CEL I have 2 cylinder injectorc control valves stuck open
