Anyone OCD about parking?
Discussion in 'Questions From New Drivers' started by mjfreespirit, Dec 8, 2016.
  1. mjfreespirit
    mjfreespirit Light Load Member
    257
    171
    Dec 4, 2012
    Florida
    Are you the type that backs into a spot...almost perfectly, but find the innate need to make your parking job as geometrically correct and center as possible?
    I'm guilty of this. I've gotten much better at backing over the last few years, and now I'm pulling up, squaring off getting over that inch over that way....yes I must be perfectly center in a spot. Guess it comes from my carnival truck driving when loads needed to be exactly on location or maybe I'm just crazy.
    Anyone have this?
  3. pocketaces
    pocketaces Light Load Member
    158
    318
    Aug 23, 2016
    Lol. Guilty. And the steer tires better be straight too. Can't be looking like a rookie.
  4. mjfreespirit
    257
    171
    Dec 4, 2012
    Florida
    Oh yea, steering wheel in the truck can't be crooked either!
    ncmickey and NavigatorWife Thank this.
  5. Blackshack46
    Blackshack46 Road Train Member
    What to do if your steering wheel is ####ed but your steer tires are straight. That irks me.
  6. Ridgeline
    22,720
    123,244
    Wow what happens when you can't park straight or have to park where your wheels have to be turned?
    Come on, overthinking makes lousy drivers.
    Just be courteous, make sure there is enough room for people to get by or to have the truck next to you pull out.
  7. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    To fix that problem on most trucks with a recirculating gearbox, make sure your front wheels are pointed straight or the direction you choose, open your hood up and loosen the steering shaft pinch bolt that attaches the steering shaft to the gear box.
    Use a pry bar and gently pry upwards to release the shaft from the splines on the gearbox.
    Go inside your truck, straighten the steering wheel, go back outside and reset the steering shaft back on the gearbox splines (you may need to gently use a mallet to set it on the splines) and tighten the pinch bolt.
    Lepton1 and Blackshack46 Thank this.
  8. Byx
    Byx Light Load Member
    150
    225
    As long as I am in at least two spaces, can throw trash out the passenger window without hitting a trashcan or dumpster, get good signal for my travel satellite dish, be within spitting distance of the nearest food source, and as far away from those dang company driver rookies I'm good.
    91B20H8, Bakerman, addrenjunky and 2 others Thank this.
  9. 03machwon
    03machwon Medium Load Member
    305
    426
    Jun 19, 2013
    Yes I always make sure I am straight and centered in a spot. would be nice if all drivers would do this as it would give us oversize guys more available spots
    Lepton1 and ncmickey Thank this.
  10. bzinger
    bzinger Road Train Member
    16,650
    66,161
    Dec 10, 2014
    omaha , ne
    As long as I'm between the fuel pumps I'm good lol
  11. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    I don't measure my parking jobs in millimeters but I do measure them in inches and I try to be centered within an inch or two.
