APU battery powered not working
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by markk, Apr 26, 2021.
  1. markk
    markk Medium Load Member
    566
    197
    Nov 14, 2011
    Hi, 2017 pete 579. Just bought it. Dealer left bunk heater on and ran down batteries. APU control display was lit up. They jumped truck to start it. Hooked up jumper to driver side batteries. Started truck and now the apu display does not work. No 12v at hot wire for display.
    Any ideas what could have burnt out ?
    My guess is one of the relays.
    Arrow Truck won't pay for what they caused.
    Thank you
  3. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    Check at the battery box first.
    They may have disturbed or broken a connection to the battery?
    Also could be an inline fuse to it at the battery that might be an issue?
    markk Thanks this.
  4. ridin_rough
    ridin_rough Bobtail Member
    38
    36
    Apr 26, 2021
    what type of apu? Carrier ComfortPro or Thermo King tripac evolution? Makes a difference on how things are setup and where to start.
  5. AModelCat
    164,526
    Trace the wire that's supposed to have 12 volt on it back until you find the issue.
  6. ridin_rough
    38
    36
    Apr 26, 2021
    It's not that simple. The power is supplied through a circuit board either in the apu outside or under the bunk in a fuse box attached to the evaporator case. If it's a TK, it's pretty simple. If it's a Carrier, it's not so simple. They are night and day different. TK uses automotive technology for cooling and Carrier uses a heat pump setup - mini version of what you use in your house. It runs off a generator that supplies 120v to the ac compressor. TK uses an automotive belt driven ac compressor.
    Both use a circuit board to supply the power but the carrier unit is much more in depth with how they tie into the truck.
    Jumping the truck could have fried the circuit board.... just like it is possible to blow up a battery or fry the ecm when jumping or welding on the truck.
    As I said, the little tiny wire going into the thermostat control is not as simple as tracing the wire. Most likely, blown fuse.
  7. ridin_rough
    38
    36
    Apr 26, 2021
    And each have easy ways of troubleshooting the problem... the carrier unit has a reset button on it that could have tripped. Similar to a gfi plug in your bathroom
