APU expert?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by WREN, May 23, 2021.
  1. WREN
    WREN Medium Load Member
    378
    239
    Jul 17, 2017
    Florida panhandle
    Anyone on here an expert on these things?
    I serviced mine yesterday. Changed the oil, oil filter, and fuel/water separator but not the inline fuel filter. Also degreased the engine and radiator with purple power and then hosed it all off.
    1.5 gals of oil on refill (delo 15w40)
    Prefilled the fuel/water separator filter with offroad diesel (from the same tank that I use for my tractor)
    Afterwards I started it up and it started but smoked like hell. Looked like a hung injector. That lasted a minute or less and cleared up and then shut itself off and tripped breaker.
    Reset breaker and restarted and it would fire and run a brief second and shutoff and trip breaker.
    After a few times I drained the separator and refilled again and now it just turns over but no fire and trips the breaker. See video
    I'm gonna get the inline filter today and see if it will start.
    Also, hit it with a shot of starting fluid (small squirt) and it will start and run briefly.
    Ran fine prior to the service but may have had an oil leak which is the reason for cleaning the engine.
  3. shooter19802003
    5,654
    42,113
    Feb 8, 2010
    You might have gotten some water and degreaser where it ought not be......wiring, ecm....connector...etc. take connectors apart and let them air out. Then add a small amount of Dielectric grease. That is where I would start. Good luck.
    WREN Thanks this.
  4. WREN
    378
    239
    Jul 17, 2017
    Florida panhandle
    @shooter19802003 thats what I'm hoping also. Hopefully it dried out over night and today before I mess with it again
    shooter19802003 Thanks this.
  5. D.Tibbitt
    156,783
    Is it a thermomking? You should hear a really fast clicking noise along with the buzzer sound when you first switch it on , the clicking sound is the fuel pump priming up . i did not hear that in the video. Mine sounded exactly like yours , cranking and cranking and cranking , never turning over would turn over ans fire for a couple seconds and then shut off. Bad fuel pump. They are easy to replace. The 2 bolts you see on the front of the frame there, should be the fuel pump if it is like mine.
  6. 062
    062 Road Train Member
    6,323
    33,959
    Oct 20, 2013
    You’ve lost prime and they are a pain to get going again. I would confirm that the lift pump is working, then cycle it about a dozen times without letting it start. There’s a Phillips screw head on the banjo bolt for a injector line. Let it spin over and crack the line to let air out and be ready to close it when it starts to run.
    @reeferwrencher
    p608, WREN and reeferwrencher Thank this.
  7. reeferwrencher
    reeferwrencher Medium Load Member
    613
    1,577
    Aug 4, 2018
    Lost prime and as stated above they can be hard to get going.A surefire way to get it going is to crack the 11/16 fittings on the injection pump and jump 12 volts to the fuel pump and bleed all the air out.A bit of work but I always hate cranking the hell out of a starter.Good luck
  8. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Did you change the inline filter in the back corner. If newer version there is a screen
    In front corner bottom. Sounds like electric pump not working.
  9. WREN
    378
    239
    Jul 17, 2017
    Florida panhandle
    Electric pumps is working fine and I have it running after spending a couple hours on it. But, it ran for about 45 mins before and died and acted like it wasn't primed. So I got it going again and will see this time.
  10. 062
    6,323
    33,959
    Oct 20, 2013
    It could be fuel shut off solenoid. You can unbolt it to see,it will dribble a little oil.
  11. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    what does the switch say. the control knob that is ac, fan, heat. if it shows red alt. then its about that.
