APU question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 1source, Nov 6, 2012.
  1. 1source
    1source Bobtail Member
    43
    11
    Sep 26, 2012
    Old town ,AL
    Can you run your APU at the same time with your truck motor. I ask this because my truck altnaor went out and I no the apu keeps the batteries charged.
    DoneYourWay Thanks this.
  3. Numb
    Numb Crusty Curmudgeon
    4,286
    10,156
    Jan 30, 2012
    Charlotte, N.Carolina
    I've seen guys leave it on all the time. don't know why, never had one. they pull in and its running when they back into dock.
  4. robr
    robr Bobtail Member
    Yes you can. I have run the APU when I lost my fan belt. I was told it could be hard on the water pump on the APU unit as it is not designed for the amount of pressure the truck motor puts out, but I did not have any problems.
  5. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    only some models can do this, or can be modified in their programming to do so. Stand alone units that are not connected to the trucks coolant system will not have the water pump issue.
  6. EccII
    EccII Bobtail Member
    9
    Oct 24, 2012
    on ours you can
  7. 1source
    43
    11
    Sep 26, 2012
    Old town ,AL
    Thanks everyone. my APU is tied into the truck cooling system. and I did't no if it would case the APU to over heat.
  8. Flightline
    Flightline Road Train Member
    2,345
    1,167
    Oct 1, 2011
    Almost There
    If they are tied together, they can run at the same time. But the APU alternator will not put out the capacity you could need with lights and blowers on a steady basis. But it should get you by for a while.
  9. 1source
    43
    11
    Sep 26, 2012
    Old town ,AL
    I thank you for the info
