Apu not warming coolant for the truck.
Discussion in 'Ask An Owner Operator' started by pavrom, Jan 28, 2026.
  1. pavrom
    pavrom Road Train Member
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    I had thermoking apu installed on my truck sometimes in November with the main purpose of prewarming my coolant for easier starts . I remember testing it after installation and believe saw a coolant temperature gauge showing 120 at the time of truck start . recently I noticed that apu is working but probably only charging my batteries , coolant temp gauge sits right where it is with cold engine without apu ...bit below 100 , checked coolant hoses from apu ( one warm as it should be ) ...any ideas or suggestions, I didn't touch my engine block before starting , but looking at temp gauge I think it is outside temp . I did start my truck at -15f last Friday from 2nd attempt with ton of white smoke as usual winter start in this weather
  3. Arctic_fox
    4,506
    25,420
    Sep 16, 2016
    Apu wont provide enough heat on its own to warm the coolant when it is that cold. Not unless you have a preheater or something on it. Bit like trying to warm your entire house with a small space heater. Not going to happen. At best it will likely boost the temps a bit from -15 to say 20 or 30.
    Siinman, D.Tibbitt, Bean Jr. and 3 others Thank this.
  4. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    You probably have 10-13+ gallons of coolant to heat. It would probably take several hours run time to bring the coolant temp up for the motor.
  5. Arctic_fox
    4,506
    25,420
    Sep 16, 2016
    Assumeing it can even make enough heat in the first place. With it being that cold, even the ambient temps with the coolant pushed through the radators (1 truck 1 apu) from the pump is going to strip most/all of the heat out. I have a 5kw coolant heater and it will barely get my coolant to 80 degrees when its -15 out. And thats a dedicated heater.
    Little apu trying to transfer heat?. Not a chance in bloody hell you get above sub freezeing temps.
  6. pavrom
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    will probably install oil heater or block heater .. whatever it is cold
    blairandgretchen Thanks this.
  7. pavrom
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    ...ran 12 hours during that extreme weather ...I guess it is all about weather
  8. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    That would be enough for me. Oil no longer molasses, and coolant in the high teens at least? My truck is starting!
    Siinman, Oxbow and Rideandrepair Thank this.
  9. snowwy
    snowwy Road Train Member
    20,612
    13,331
    Jul 6, 2009
    Heating things from dead cold isn't going to happen. Keeping things warmed up a little after running has a better chance.
    Your truck already has a block heater. Or it should. And hopefully it works. You'll just have to figure out the electricity part. Like a generator with 3 prong plugs and a extension cord.
  10. pavrom
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    ...can block heater feed from inverter? , not sure how much it will drain , but having apu as charging for batteries should offset it
  11. xsetra
    xsetra Road Train Member
    5,196
    7,146
    Aug 21, 2011
    How many watts is your block heater? How many watts does your inverter put out? What is the output of your APU?
    IF the alternator has a 120 amp output, a conversion charts says that is 14,400 watts.
    Make sure the inverter is rated enough watts to operate the block heater. Internet search shows Block heater varies from 750-2000 watts.
    Siinman, pavrom, nikmirbre and 2 others Thank this.
