are Fitzgerald glider ELD EXEMPT ?
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by Gen Z, Aug 19, 2018.
  1. Gen Z
    Gen Z Bobtail Member
    13
    hi, i learned that when the detroit 60 serie is remanufactured they change the original serial number of the engine
    remanufactured engine : RE1234567
    original serial number : 06R01234567
    and someone said on this forum that the remanufactured detroit engine are not exempt
    Anyone stopped by the DOT with this sort of serial number 06RExxxxx or RExxxxxx
  3. ZVar
    ZVar Road Train Member
    10,911
    23,832
    Sep 10, 2010
    Flint, MI
    What is the model year on the engine? If 1999 or older it's exempt. If newer it's not.
    Studebaker Hawk Thanks this.
  4. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    We have trucks in our little fleet that are exempt, but they all have ELDs in them, and they work. So, I would not base my purchase decision upon an ELD. I would be looking for reliability and fuel mileage. And if considering a Fitzgerald truck, make sure it has the Detroit Factory Remanufactured motor under the hood. You do not want the Fitzgerald in house reman, as they use inferior Chinese parts vs the Detroit OEM parts found in the Detroit factory reman motor.
    Bank_Lbr Thanks this.
  5. Night_driver
    Night_driver Light Load Member
    295
    82
    Sep 20, 2014
    Grand Rapids, MI
    I was looking to get a Fitzgerald Glider with Detroit motor and I don't believe you can get a Factory Reman engine. You can however request they use OEM parts
  6. Night_driver
    295
    82
    Sep 20, 2014
    Grand Rapids, MI
    I've contacted Detroit service and they cannot tell what model year the original engine was. They only tell you the year engine was rebuilt.
    Oldironfan Thanks this.
  7. Justrucking2
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    Fitzgerald as of a few months ago used an OEM Detroit reman, where it it is sourced, I do not know, but it carries a Detroit factory warranty with straight from Detroit factory tuning on the ECM if I heard correctly.
    The Fitzgerald reman is made in house and warrantied through Fitzgerald. The Detroit OEM motor is a $5000+ up charge.
    The Fitzgerald motors were failing at 200,000 miles, Chinese parts and a really bad in house tuner. I learned this when down in Atlanta in framing my truck. I visited a shop that had over 200 of these Fitzgerald rigs, they had a few Detroit motors on the shop floor, it was an interesting conversation.
  8. Kawinige01
    Kawinige01 Heavy Load Member
    864
    1,150
    May 30, 2016
    South Fla
    Im at 125 with my fitz built 60 series.. it uses about 3 gallons every 7k miles. And puffs white smoke like crazy after idling for a while. Oil pressure isnt to low right around 50 ish when cruising down the highway
  9. Kawinige01
    864
    1,150
    May 30, 2016
    South Fla
  10. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,543
    May 22, 2017
    They can to, they just like to not say.
  11. Oldironfan
    5,776
    5,543
    May 22, 2017
    This engine is getting tired. Take it back to be fixed right. Tell them to have Steve from Sparta, the contract guy to look at it.
    Your oil should be at 70psi on a healthy 12.7. 50psi is an old engine pressure. Your mains are getting wore out.
