Asking for advice -got pulled
Discussion in 'Experienced Truckers' Advice' started by Boacaza, May 26, 2021.
  1. Boacaza
    Boacaza Bobtail Member
    Hi there! Was pulled over and got overweight on my drive with 2500lb in Utah. And a false log violation .
    Was checking on UT penalties and fees for overweight and so 0.04/lb . That makes around $100 . I would gladly pay the fine but was thinking that I need my license clean .
    Will a overweight ticket damage my license ?
    Should I hire somebody to help me ? Can the log violation be fight ? Is it worthy? I am lease to another company and would like to fix it if I can . The log problem was that I was off duty in one location and in on duty 92 miles away . No driving between…. I do know my mistakes. Thanks for any advice.
  3. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    The log falsification is your bigger concern.
  4. dunchues
    dunchues Medium Load Member
    555
    960
    Mar 23, 2012
    new brunswick
    A lawyer who's local to the courthouse is your best bet, they can usually get the charge down to something minor that won't hurt your record. You'll still pay the fine and you'll have their bill too but it's the cost of protecting your license.
    okiedokie, slow.rider and Boacaza Thank this.
  5. HillbillyDeluxeTruck
    5,942
    30,372
    Mar 3, 2013
    San Antone
  6. snowwy
    snowwy Road Train Member
    20,610
    13,324
    Jul 6, 2009
    Overweights and logs aren't moving violations.
    They'll effect your csa though since you were inspected.
    slow.rider Thanks this.
  7. Flat Earth Trucker
    4,307
    16,433
    Nov 19, 2018
    Just fines. Nothing to really be concerned about. However, you do actually need to log check in/check out at the shipper and consignee as On Duty time, otherwise it looks like you're just joyriding. Same goes for pre-trip inspections.
  8. Noremorse
    Noremorse Bobtail Member
    7
    5
    Jan 28, 2021
    Your ELog dont automatically change to driving when you start to move at like 10 MPH?
    striker Thanks this.
  9. Brandonpdx
    Brandonpdx Road Train Member
    4,686
    4,758
    Dec 27, 2007
    Elkhart, IN
    I thought it was usually 5 mph on ELD's. Just fast enough to where you can creep around a parking lot off duty if you need to.
  10. Flat Earth Trucker
    4,307
    16,433
    Nov 19, 2018
    It's 5 mph.
    You can get around this by changing your On Duty status to Yard Move. Yard Move allows tractor speeds up to 20 mph. Afterwards, edit your logs to Sleeper Berth or Off Duty.
    Works for me. You can make it work for you.
  11. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,863
    Apr 29, 2020
    Might not work so well during a Log Audit. Every edit SHOWS UP as an edit. Too many will cause suspicion. Good luck with that.
