Assign Shipment
Discussion in 'Schneider' started by FatDaddy, Feb 1, 2016.
  1. FatDaddy
    FatDaddy Road Train Member
    4,314
    10,375
    Dec 23, 2008
    Katy, TX or Swedesboro, NJ
    I'm a little slow so if this had been available for awhile then my apologies in just now noticing it. Lol.
    So anybody use is yet? I'm always leery about something new. Sounds good in theory if it eliminates a phone call...but I'm guessing one of the bugs will be the system won't reassign the other loads on you.
    I'm guessing this will used primarily when something cancels on you and you can find something to replace it with to the same region as your next load so you don't have to clear your board.
  3. centralmi
    centralmi Light Load Member
    82
    70
    Aug 15, 2014
    Cincinnati Oh
    I've used it several times while it was in the trial period. It works well for cancellations or if you just need to slip one in. They are fast getting it added to your workflow. I like it.
    FatDaddy Thanks this.
  4. freightwipper
    freightwipper Road Train Member
    9,366
    11,439
    Mar 24, 2014
    OTR
    I tried it once (while they were in testing and offered it to some ICs) and didn't work out.
    While the idea is good, it's not instant.
    So for me by the time they got around to it the load was already gone.
    Good loads don't sit, period.
    What they should do is enable us to be able change around our loads easily without having to go through a middle man.
    Pork Chop Express and FatDaddy Thank this.
  5. centralmi
    82
    70
    Aug 15, 2014
    Cincinnati Oh
    Yeah, that would be best
  6. FatDaddy
    4,314
    10,375
    Dec 23, 2008
    So you are saying if you assign a shipment it dosent hold it for you? Somebody else could assign the same shipment through the normal methods where it's instant and take it from you while your request is processing?
    Did I understand that correctly?
  7. freightwipper
    9,366
    11,439
    Mar 24, 2014
    OTR
    YES.
    When you use this new option to assign a new shipment in between assigned loads it doesn't happen right away, it goes through a Schneider middle man and Schneider themselves even say "it could take up to 30 min".
    So all it is basically is a request.
    If someone else assigns the load to themselves before the request is looked at and processed you're poop outta luck.
    Happened to me before, it sucks.
    I hate being beat to loads. :biggrin_25510:
    If you wanna fill in with cheap freight you have better luck for it to work out and you'll save some time by not having to call in.
    It's a step in the right direction but doesn't solve everything.
  8. FatDaddy
    4,314
    10,375
    Dec 23, 2008
    Gotcha. Yeah that's a bit of a flaw in it. Hopefully I won't need to use it.
  9. drvrtech77
    drvrtech77 Road Train Member
    15,420
    150,750
    Mar 20, 2010
    Everyone I've talked to that used it it's taking less than two minutes to get it put on
  10. rickybobby
    rickybobby Road Train Member
    4,843
    6,672
    Jul 10, 2010
    greensboro, nc
    I just use the phone.
  11. TennMan
    TennMan Road Train Member
    7,866
    9,658
    Sep 21, 2011
    Hazzard County Jail !!!!!
    I think it will lead to drivers cherry picking the best loads and then using that option to fill in between.
    I was one of the "testers" and never had a need to use it. Imagine that a load never cancelled for me to try it out but I did send in my concerns on it being abused.
    If they let us insert a load they should also let us remove a load.
    That would be a useful tool.
    Home_on_wheels Thanks this.
