ATRO bushings
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rollin coal, Aug 20, 2020.
  1. rollin coal
    rollin coal Road Train Member
    13,611
    27,976
    Mar 29, 2008
    TN
    Anybody using ATRO poly bushings in their suspension? Are they good?
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Tried them, pretty harsh. OEM rubber seems to hold up better.
    pushbroom and rollin coal Thank this.
  4. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    I use them they last a lot longer then OEM.
    Muddydog79 and rollin coal Thank this.
  5. mtntopbound
    mtntopbound Bobtail Member
    38
    71
    Sep 9, 2019
    Everywhere man
    I tried them as well on freightliner airliner and they transferred too much to the chassis, I went back with Oem rubber much better ride.
    rollin coal Thanks this.
  6. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    Rubber will always ride better, poly will hold up to grease and oil better.
  7. rollin coal
    13,611
    27,976
    Mar 29, 2008
    TN
    Well, being as I had virtually no bushings left these Atro's certainly tightened things up good and I think they ride great compared to no bushings at all popping and slamming lol. My KW had OEM rubber bushings and I do believe it was a little smoother but I don't think it was a huge difference to these. These bushings eliminated 6 grease fittings on the front leaf spring pins which is a plus in my book with 6 less to hit every time. Hopefully they last a looooong time.
    Muddydog79 Thanks this.
  8. dirthaller
    dirthaller Road Train Member
    1,126
    13,418
    Sep 22, 2011
    Coloratah
    What happened to the KW? I thought they were gonna bury you in that thing.
  9. rollin coal
    13,611
    27,976
    Mar 29, 2008
    TN
    It was a good truck and it sucked getting rid of it but the ELD mandate forced my hand there it being a 2003. I know there's a lot of people running 2001 and up with "1999" engines but that #### won't fly where I'm leased at and I wouldn't even risk it on my own. A little over a year ago a buddy getting out of the business had this clean flattop 1999 FLD and I knew it was a good truck so I ended up with it.
  10. BoostedTeg
    BoostedTeg Road Train Member
    1,871
    3,569
    Jun 2, 2008
    Boise ID
    That’s a clean looking 99
    rollin coal and dirthaller Thank this.
  11. rollin coal
    13,611
    27,976
    Mar 29, 2008
    TN
    Thanks, it is a clean truck. Did need re-bushed really bad tho. About the only thing that hasn't been replaced or gone thru are the rears.
    spsauerland Thanks this.
