Automatic failures
Discussion in 'Trucking Schools and CDL Training Forum' started by Ugminer, May 10, 2022.
  1. Ugminer
    Ugminer Light Load Member
    62
    45
    Apr 1, 2020
    When taking the skill test. I know you are allowed 2 free get out and looks. If you get out a 3rd time is it just points docked or automatic failure? An also what about hitting a cone?
    Thanks
  3. Kyle G.
    Kyle G. Road Train Member
    3,901
    20,574
    Jan 23, 2016
    Eastern Iowa
    i believe you are allowed as many get out and looks as you want, but only one pull up.
  4. newnew
    newnew Bobtail Member
    22
    36
    Dec 4, 2021
    Atlanta, GA
    It's ONE free GOAL/pull-up for straight back and TWO free GOALs/pull-ups for the rest of the maneuvers. You just get points taken off for any additional GOALs/pull-ups.
    P.S. It may depend on each state.
  5. Knightcrawler
    Knightcrawler Road Train Member
    1,766
    6,912
    Apr 10, 2017
    Mpls, Mn oops Ocala, Fl.
    Depends on the state. Minnesota, once you stop you are done. You can pull up as many times as you want, you have 5 mins to park it. But once you set the brake, its over. Also, the only "automatic fail" is shifting/stopping on RR tracks (other than getting into an accident of course). But most trucks have automatics now, so this isnt an issue.
  6. Ugminer
    62
    45
    Apr 1, 2020
    That's what I thought. If you hit a cone its just a point also right? I'm in indiana
  7. newnew
    22
    36
    Dec 4, 2021
    Atlanta, GA
    Yes, the number of points lost I don’t know.
  8. newnew
    22
    36
    Dec 4, 2021
    Atlanta, GA
    For my test (in Mississippi), it was an automatic fail for hitting a curb, not using blinkers, and not following directions; that could mean what the tester is telling you to do or where the tester is telling you to go.
  9. newnew
    22
    36
    Dec 4, 2021
    Atlanta, GA
    And of course don’t speed!!
  10. flood
    flood Road Train Member
    4,168
    4,046
    Dec 25, 2010
    a automatic can shift crossing RR tracks
    .. an automated can't
  11. jmarc77
    jmarc77 Light Load Member
    162
    428
    Sep 17, 2021
    In my state, you get one GOAL and one pull up for the straight line. You get two GOALs and two pull ups for the rest of the maneuvers. Each additional pull up/GOAL costs one point. Hitting a cone costs 2 points. You can lose 12 points and still pass.
    Other common auto fails- hitting a curb, exiting the vehicle unsafely (3 points of contact, facing the truck). Also the air brake test is pass/fail, it must be done exactly.
    newnew and flood Thank this.
