Automatic for tanker?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by 77fib77, Sep 11, 2018.
  1. 77fib77
    77fib77 Road Train Member
    11,601
    76,339
    Jul 7, 2010
    St Louis
    I was looking at the Freightliner web site. It seems all trucks come with a 400 dd15 with a 12 speed auto. Or, you spec otherwise. Do automatics make good tanker trucks? I have a 10 spd manual with 465 dd15. It's fine but I do wonder about the future.
  3. scythe08
    scythe08 Road Train Member
    2,894
    3,800
    Mar 19, 2007
    Portland, Or
    I hauled milk with one recently. To be honest, I liked it. For OTR you really wouldnt see much of a change from a manual. But city or heavy traffic light what I deal with everyday, it actually made my job alot more enjoyable.
    But I had alot less control over my surge and I absolutely hated started and stopping. Even in manual mode it still takes control of the bottom few gears when you get below 5 or so mph. So if you're coasting up to light or getting ready to turn, it can hunt for gears for a few seconds and its irritating. Going in reverse is a different item as well. You cant feather the clutch to ease it back. The bays I back into every day have a bump to let you know where your axle is. All the guys that go past it and end up over the curb behind it are always in automatics
    homeskillet, AM14, slim shady and 2 others Thank this.
  4. ErieMcDreary
    ErieMcDreary Medium Load Member
    460
    394
    Dec 4, 2016
    Erie PA
    I drove a Volvo when I worked for FedEx, and I really liked their I-shift. Even maneuvering or hooking doubles it was very nice.
    I now drive a Peterbilt. I hate that autoshift trans so much I'm considering buying my own truck just to get away from it. Trying to back it into any position to unload is a real PITA!!! It won't coast, you have to be on the throttle, then it gets going too fast and when you back off it stops. As stated, you can't control the surge, I think it actually makes it worse. It always wants to be in as high a gear as possible, great for mileage, sucks for hill climbing! Going uphill it starts upshifting then dropping back down when it can't pull the higher gear. And yeah, if you don't completely stop at a light or something, it hunts for the gear, while you're trying to get moving. It shifts very hard, front of the truck jumps, makes you look like a noob that can't shift. Mechanic told me the driveshafts are much heavier than they used to be due to the shockloads, and they replace a lot of u-joints.
    I don't know anything about Freightliners auto's.
    weldertotrucker23, AM14 and 77fib77 Thank this.
  5. J Rich
    J Rich Medium Load Member
    363
    380
    May 28, 2018
    Atlanta Ga
    As long as the tank has baffles you're golden. I drove a Mack with 10 spd auto once. No baffling. If it did shift right you thought you got rear ended by a freight train.
  6. 77fib77
    11,601
    76,339
    Jul 7, 2010
    St Louis
    I was surprised to see autos and 400hp to be standard equipment. Tanker I have to be smooth to keep it happy.
  7. slim shady
    slim shady Road Train Member
    3,468
    14,690
    Sep 14, 2011
    Chicago, Il.
    At Quality Carriers I drove a Mack with the m12 auto for a year and truth be told I loved it. It was real nice in this Chicago traffic. Using reverse took some getting used to.
    VIDEODROME Thanks this.
  8. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    the future?? what happens in the future? people become completely retarded and cant drive manual?
    77fib77 Thanks this.
  9. AM14
    AM14 Road Train Member
    1,501
    2,427
    Oct 6, 2015
    Jefferson Twp. NJ
    My biggest problem has already been stated. If you're really sloshy with the thin stuff, the trans can't seem to decide what gear it wants to be in. Constant shifting or, it just gets stuck between gears for lack of better term. I leave it in power mode or manual and keep the hill start assist off. It is so much smoother that way. Economy mode is useless for stop and go traffic. Leaving the jake off helps too. Im in a Volvo BTW
    tscottme and homeskillet Thank this.
  10. mustang190
    mustang190 Road Train Member
    2,883
    6,218
    Jan 18, 2011
    Florida Panhandle
    I was driving a 2016 Mack with a 6 speed stick. Shifted like butter, I could control the surge real easy.
    The autos will beat you to death.
  11. ChicagoJohn
    ChicagoJohn Road Train Member
    2,390
    2,755
    Jan 14, 2016
    Chicago
    Both Volvo & Mack can b programmed for tankers. I'm not exactly sure what changes it makes, but I do know if you ask a dealer they can change the programming. I'm not sure if Freightliner offers a tanker setting or not.
    Most trucks I see in tanker fleets are 450 hp.
