Automatic Truck
Discussion in 'Ask An Owner Operator' started by haider99, Mar 19, 2017.
  1. haider99
    haider99 Medium Load Member
    685
    108
    We will be purchasing an new truck for myself and my father. We would like to purchase a automatic for the first time and are looking at 2012- 2015 Volvo or Cascadias. We never have purchased an automatic before and I would like to hear from owners about the reliability and ease in finding parts for them. Also, how hard is it to work on them for mechanics?
    We have experience with Cummins, D12 and Mercedes engine and we would like to purchase D13 in Volvo or Detroit in Frieghtliner.
    What are the pros and con of Automatic?
    What are the pros and cons of Cascadia vs/ 670/780.
    Truck will be used to pull a dry van or reefer.
    Thank you
  3. Getsinyourblood
    Getsinyourblood Road Train Member
    1,274
    1,810
    Jul 5, 2014
    Retired. North Texas
    Just curious, why do you want an automatic?
  4. Steel Dragon
    Steel Dragon Road Train Member
    2,681
    2,833
    Nov 23, 2015
    Volvo makes a nice truck.
    Dealer network is your only avenue for parts.
    Freightliner can be repaired anywhere.
    I like the KW and Pete..but the jakes are rather weak..but a more comfortable and quiet truck.
  5. Coolbreeze
    Coolbreeze Light Load Member
    199
    115
    May 13, 2008
    Atlanta, Ga.
    My Eaton Autoshift has been great. Shifts a little slow, but I've been told that the dealership can can adjust that within the computer.
    Getsinyourblood Thanks this.
  6. win-some-loose-less
    win-some-loose-less Medium Load Member
    691
    997
    Apr 19, 2010
    Mount Vernon tx
    if It has to be a auto it would be Volvo i-shift.. I was skeptical since all the other autos I've driven were junk, but now I'm drinking the I-shift koolaid..
    ReeferOhio Thanks this.
  7. ReeferOhio
    ReeferOhio Medium Load Member
    596
    557
    Nov 29, 2010
    If I had to choose, I-shift all the way. We have a Mack with the Mdrive (same as an IShift) it's the nicest auto I've ever driven. Never thought I'd like an auto.
  8. Coolbreeze
    199
    115
    May 13, 2008
    Atlanta, Ga.
    My company has some Mack trucks that have the I-shift. We had problems with the manual setting. It wouldn't work. I've heard that Mack is working to resolve the problem.
  9. jlafume
    jlafume Light Load Member
    241
    324
    Jan 6, 2011
    Victorville,Ca
    U will have electrical problems when the connectors get old
  10. Chinatown
    Chinatown Road Train Member
    77,549
    182,828
    Aug 28, 2011
    Henderson, NV & Orient
    Best driving experience of my whole career was when driving a Volvo with Volvo engine and Volvo automatic transmission. Wasn't nearly as tired at the end of the driving day. This was pulling tankers coast to coast.
    If I were to buy a truck, it would be the Volvo with Volvo I-Shift automatic transmission.
    dustinbrock Thanks this.
  11. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,142
    Mar 5, 2016
    White County, Arkansas
    We got a 2001 century with a rockwell auto assisted by a manual paddle under the steering wheel for mountain work etc. I got the truck at 20 miles and got the wife trained on it. We teamed on that thing 221000 miles that first year.
    As a team, we never shut down. You have to shut down at least 30 minutes each day so that the transmission can empty it's software buffer. If you did not shut down, it bricked. Requiring a tow to the company shop equipped with a computer to restore it very similar to reformatting our PC's and reinstalling everything. And off we go again. We had two tows that year until dispatch was told to take it easy and allow us to take 30 minutes to a hour to shut it off.
    I'll die with a manual in my hand, there is nothing like a manual done right. However the auto we had was tuned very carefully mated to the 500 detroit we had that every time that thing started lugging enough for me to reach to shift (That took about a couple of months to stop doing.. lol) she will shift.
    On some really bad days where we had a couple of jackknifes on ice that auto maintained the power to the drives and I think it understood what the situation was because the wheel rotation versus power versus road speed during a jackknife was really abnormal. It was just enough to get out of it breaking one of the rules of never applying or adding power to try and break a jacknife. In the old manual you would slam it into nuetral and then work really fast to get her back as your speed dropped usually doing either stab or squeeze braking. ABS coupled to the auto took care of that problem too. We tripped it a time or two and it did well.
    But the two tows that was needed gave us a bad name because the loads absolutely cannot be missed appointments and being totally busted and having to be given to another team which had to give up whatever it was doing and race back to dallas to get this one... it's no wonder dispatch did not like it too much.
    In bad traffic that auto took alot of pressure off. And again when people did crazy things requiring me to trip the ABS and get that thing stopped like right now to avoid hitting them (And I had to make room where you normally did not have it before impact...) you learned to back off a bit.
    Backing with it is not that fun. You almost have to have a eggshell on that thing to keep it right at 1300 rpm above torque all the way back. The flip side is good, you evaluated the situation and made sure you got it in there in one single move. =) That became a trademark of mine. A favorite display of skill. smooth move all the way into the space and done one time without stopping or pulling up.
    Would I buy a auto? no. I'll get a 13 or 18 speed manual first. Either under drive or double over.
