Auxiliary Switches
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by newguy76, Nov 18, 2019.
  1. newguy76
    newguy76 Light Load Member
    104
    31
    Aug 14, 2013
    Del Rio, TX
    Gonna be installing some everblades heated wiper blades next week on my 2019 cascadia. On the dash switch cluster, there is a couple of blank spots available. Is there a way to add an auxiliary switch there that would look factory, rather than ghetto fabulous? Would there be extensive wiring involved?
  3. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    It will look as good as the effort you put into it. If the wiring isn't already there, you'll need to run your own including the relay and switch.
    Tip: if you want a neat hole, don't use a cutoff wheel.
    jammer910Z and Farmerbob1 Thank this.
  4. Ridgeline
    22,720
    123,238
    If you have a couple blank spots with the switch clusters, then see what the dealer can order for an aid switch, this way it looks factory and very neat. The switch may be $30 but nothing like it looking factory.
    jammer910Z Thanks this.
