Axle compatibility kenworth
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Jleippi, Jan 3, 2025.
  1. Jleippi
    Jleippi Bobtail Member
    37
    8
    Mar 6, 2024
    Hello , does anyone know if there is any leeway on using different steer axles in different trucks ? I have a 1997 t800 and a donor axle from a 2000 t800 . Different part numbers. Is it possible to use the axle from the 2000 kenworth t800 on the 1997
  3. Ridgeline
    22,720
    123,225
    Call kw and ask if the part number on the older one is superseded and if the newer one is the same number.
  4. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    should be a bolt in if using the complete axle
  5. Jleippi
    37
    8
    Mar 6, 2024
    You sure ? The center bolts are 1/2 inch different in distance apart . The brackets that hold the leaf springs appear to be the same part . Will I have issues with steering linkage parts ?
  6. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    are they the same width spring
    Oxbow Thanks this.
  7. Jleippi
    37
    8
    Mar 6, 2024
    I’ve only eye balled it but it appears that on leaf spring is more narrow.
  8. Jleippi
    37
    8
    Mar 6, 2024
    Also the abs system may not function correctly.
