Axle temperature question.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by LoneRanger, Nov 21, 2021.
  1. LoneRanger
    LoneRanger Road Train Member
    3,695
    9,605
    Jun 3, 2018
    After about 400 miles my driver side axles are colder then my passenger side axles. In fact my passenger side axle one of them is almost to hot to touch.
    I want to get a better understanding on what i need to look for when the mechanic takes it apart so that i dont get hosed on repairs.
    Also my front hub is needing gear oil every two weeks but i cant seem to find a leak.
    2013 Cascadia DD15.
    Any help is appreciated.
    blairandgretchen Thanks this.
  3. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    The hub getting hot I would say
    Possibly a bearing getting ready to fail,
    Dragging brake, caused by a slack adjuster perhaps adjusted up to tightly or another issue in the foundation brake.
    is differential low on oil?. That would cause a wheel end to get hot. But also the whole differential to get hot.
    Front hub if not slinging oil from hub oil cap has to be leaking at the axle seal. Have you cleaned the breather hole in the middle of the rubber plug. If plugged will cause excess pressure to build in hub and push oil out of seal.
  4. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    everything this guy says.
    Start with checking for oil at fill hole. Any leaks under that rear? The hubs should be pretty hot. On some long drives. My forward drive can be pretty close to my manual trans temp on long drives. I have gauges for all those temps. So we are talking close to 150 degrees.
    Pick up a heat gun and shoot all your hubs after next trip and shoot the middle of the rears. Cheap temp gun should be in your tool box
  5. LoneRanger
    3,695
    9,605
    Jun 3, 2018
    I’m feeling a drag on the driveline and I’m trying to chase it down.
    it’s the difference in temperatures that has me worrying. That’s why I’m trying to figure out why one side is hotter than the other side with no visible leaks.
    if low on gear oil, both sides should be hot, so that’s not the case. mid bearing is getting ready to go out then one side should be hot.
    but I’ll pick up my temp gun next time I’m home and see if it’s around 150F after 600 mile trip.
    mad far as the breather hole. Would you be able to show me where that would be if I show you the hub?
  6. AModelCat
    164,354
    Shoot your drums or discs too just to rule out a dragging brake.
    God prefers Diesels Thanks this.
  7. Rideandrepair
    17,534
    56,821
    Aug 8, 2015
    Breather holes in the center of rubber plug.
  8. God prefers Diesels
    4,198
    22,264
    Jun 26, 2020
    South Texas
    Can you find a place to pull over with little traffic, so you can use your Jakes to come to a stop? Then get out and touch them.
    Only one side on two different axles sure seems more like a brake problem than a bearing problem.
    okiedokie, Don379 and LoneRanger Thank this.
  9. LoneRanger
    3,695
    9,605
    Jun 3, 2018
    got none. Center of plug is solid.
  10. AModelCat
    164,354
    Breather is on the axle housing, somewhere on top. Either looks like a button or has a vent hose attached to it that points down. Axle housing and hubs are all 1 common housing.
  11. jason6541
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Pull the plug turn it over. Use a straight pin or a needle. There is a small hole in the center of that little bump on front side.
