Axle weight
Discussion in 'Flatbed Trucking Forum' started by W9in’, Apr 14, 2021.
  1. W9in’
    W9in’ Bobtail Member
    15
    11
    Sep 29, 2019
    I’m wanting to get into hauling a tandem axle rgn here soon, but I’m a bit confused on how much weight I can haul. I know with a tandem axle rgn I can’t go more than 80 gross, but what about if I have a 6 axle set up (3 on the trailer 3 on the truck)? How much can I gross at that point? May be a dumb question sorry.
    cke and singlescrewshaker Thank this.
  3. lester
    2,956
    8,078
    Jan 2, 2012
    NW, Iowa
    Depends on the state and almost every state is different. Then some states you can run the interstate and others you can't. Permits, divisible loads, lots of factors.
    Get your road atlas out and study the weights and measures charts
  4. singlescrewshaker
    4,852
    42,408
    Dec 31, 2017
    Little Havana, FL
    Are you talking about 80k as actual load weight, or did you really mean gross..?
    In the right jurisdiction, you can permit a 5 axle to 112k gross, maybe more. Assuming a heavy spec tandem tractor with 20k steer, 46k rears.. Now actually being able to get the load to scale out like that is a whole different animal..
    If you just have a run of the mill road tractor, 12k steer & 40k rears, you could permit to~97k-98k gross assuming the jurisdictions you travel allow 45k or 46k on the wagon tandem..
    W9in’, Tug Toy and cke Thank this.
  5. W9in’
    15
    11
    Sep 29, 2019
    Gotcha I was also speaking about gross.
    cke, singlescrewshaker and Tug Toy Thank this.
  6. Sportster2000
    Sportster2000 Road Train Member
    1,480
    886
    Jan 5, 2008
    Indiana
    With a tri axle trailer and a normal otr truck, carrying a bus, gross weight under 80,000 lbs. will permits be needed for the tri axle portion of the trailer for weight. The combo will not scale as a proper 12-34-34.
  7. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
