Axle's
Discussion in 'Canadian Truckers Forum' started by alfie69, May 14, 2017.
  1. alfie69
    alfie69 Bobtail Member
    I am running B-trains in Canada, why do the rear axle's have to be 46000lb?
    I'm looking for a newer truck so would like this info to search the ads.
  3. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,914
    Nov 18, 2010
    Edmonton, AB
    Spec out Super 40's. Light housings with heavy gears. I pulled a 9 axle klowbed with mine.
    orcen and not4hire Thank this.
  4. Bike rider
    Bike rider Bobtail Member
    48
    33
    Apr 11, 2016
    Someone that is a little more technically savy than me will be able to answer you about the internal differences of a 40K vs. a 46K axle, but I know the Gross Combined Weight Rating on Super 40's and 46's is anywhere from 140,000- 170,000 lbs. when compared to a regular 40K axle which will normally have a GCWR of 110,000 lbs.
  5. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    As posted, Super 40s are fine for Super-B work.
  6. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    They don't have to be. That was the normal spec years ago. Then it went to super 40's. Now there's a lot of people running normal rear ends. Just more likely to break with the lighter rear ends.
  7. Cat sdp
    Cat sdp . .
    21,239
    75,663
    Apr 8, 2012
    Orion's Belt
    It's nice to have heavy wall 46s with a lube pump....
  8. Macneil
    Macneil Heavy Load Member
    711
    426
    Dec 15, 2010
    Sudbury, ON., Canada
    Depending on where you're running the majority of the time, you could get away with running just straight 40s with a super b behind you. Super 40s would be better and 46s would be best if you running in east of Ontario for any length of time.
    I miss my super 40s with super b. Nice smooth ride vs heavy spec rears with 16-20k fronts and 5 axle behind ya
  9. AModelCat
    163,624
    What are super 40's? Some kind of hybrid of 40 and 46's?
  10. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    @Mr. Haney gives an explanation in this thread.
    daf105paccar and AModelCat Thank this.
  11. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    The truck Im specing out will have Dana 40-170's in it. It has the all the parts of a 46 rear end in a 40 housing.
    Prairie Boy and AModelCat Thank this.
