Az base plates?
Discussion in 'Ask An Owner Operator' started by fuzzeymateo, Sep 17, 2013.
  1. fuzzeymateo
    fuzzeymateo Heavy Load Member
    771
    783
    May 20, 2013
    AZ
    Looking at getting my own authority and just spoke to OOIDA. I was told that AZ base plates are around $4,000.00 per year?!! Can someone educate me on this? I checked the azdot.gov website and they don't list fees. From my understanding the age of the vehicle will impact this? Looking to register to 80,000 lbs and at buying a 2000 - 2003 tractor, (still in the planning phase.) I would probably have about 35 states listed on my cab card. I understand that IFTA requires a $3500.00 bond which 10% ($350.00) is required when issued. Also looking at registering a flatbed trailer in AZ. I once did some research and found that it would be around $500.00 (one-time fee) for a 1 to 6 year old trailer. Can someone clarify this for me? Thank you.
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I have AZ aportioned plates-AZ & CA only and they are $2,800. Sept. '13 to Sept. '14. Don't remember what my trailers were but they are permanent plates.
    fuzzeymateo Thanks this.
  4. heysteveh
    heysteveh Light Load Member
    91
    17
    Nov 6, 2008
    AZ
    Call the Arizona Commercial Motor Vehicle Division at 602-712-6775 and get it straight from the horse's mouth. I am in the process of getting apportioned plates right now for my 2007 Volvo 780 tractor and this is the number I called to get info.
  5. fuzzeymateo
    771
    783
    May 20, 2013
    AZ
    I'm attaching a link to the IRP website. It shows the fees state by state. I called that number you provided earlier today and I got a recording saying they could not give fee information on the telephone. According to the website below it looks as if OOIDA was pretty accurate. I'm just in shock seeing how much this is. AZ has got to be the most expensive state in the union to register a commercial vehicle in. The AZ Trucking Association will get a call from me tomorrow.
    http://www.irponline.org/?page=feeschedules
  6. Sly Fox
    Sly Fox Road Train Member
    1,016
    695
    Oct 29, 2009
    Your apportionment is based on miles driven. Since you'll have a vehicle without prior driven miles, your state will use an estimate for each state. And you add the estimates of your selected states. Then, based on percentage, you figure out what your total plate will cost. Your plate in Arizona may be $4,000 if 100% of your plate is AZ. but, since you're going into 34 other states, your apportionment will make AZ's chunk smaller, understand?
    My plate in Ohio for 47 states ran me $1681 last year, and Ohio only equaled $100 of that cost.
  7. fuzzeymateo
    771
    783
    May 20, 2013
    AZ
    I understand to a degree but the $4000.00 price tag is still completely out of whack with every other state in the union. So AZ must take in a bigger percentage than other states, thus the higher price tag? Sly, can you tell me if OH made you put up a bond when you first registered with IFTA? in AZ OOIDA told me it was $3500.00 with 10% required up front. I'm sure every state is a little different but is this normal? I'll have to make some more phone calls tomorrow.
  8. fortycalglock
    fortycalglock Road Train Member
    6,164
    6,613
    Jun 25, 2011
    Tourist Town, FL
    FL and PA didn't require a bond, and the first two years plates are usually cheaper than once your actual miles are used. It sounds like they are charging a crap load of AZ miles at a high rate for the AZ portion of the estimated plate.
  9. Casual Trucker
    Casual Trucker Medium Load Member
    495
    326
    Sep 7, 2012
    What R U Trying to register for $4000 ? a DC-9
    379exhd Thanks this.
  10. fuzzeymateo
    771
    783
    May 20, 2013
    AZ
    LOL! That's funny, this is what I was told by OOIDA. I haven't bought anything yet but am looking at a 2000-2003 KW W9 or Pete 379 registered to 80,000. I can't get a straight answer from anyone I talk to. The DMV won't answer questions over the phone so I'm trying to get an answer without me going down there. $4000.00 seems way out of whack but I don't know that's why I'm asking. If you check out the link below it looks like it will cost around $3900.
  11. cetanediesel
    cetanediesel Medium Load Member
    470
    186
    Mar 26, 2013
    Albany, NY
    I cant believe that New York state is better than Arizona, we only pay $50 and fill out a form to get IFTA.
