B service?
Discussion in 'Ask An Owner Operator' started by Mountaintrucker4302, Jul 1, 2020.
  1. Mountaintrucker4302
    Mountaintrucker4302 Light Load Member
    217
    436
    Sep 21, 2015
    GA
    How regularly do you guys do a b service and oil change on your trucks? I have been doing every 30, 000 miles, i am wondering if this is overdoing it or not because it turns out my company does their trucks at around 80,000 miles. I am just wondering whats the most optimal mile range to get it done.
    Dale thompson Thanks this.
  3. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    Maybe help some of us who don’t know what all a “b” service includes :oops:
    Mountaintrucker4302 and AModelCat Thank this.
  4. abyliks
    abyliks Road Train Member
    4,102
    9,640
    May 2, 2010
    ludlow MA
    Companies do longer intervals because they get rid of the trucks every 5 years for the most part
    mine gets filters and oil at 15k and greased once a month, oil and grease is cheap, replacing parts are not as well as cuts Into my beer drinking time
  5. Long FLD
    Long FLD Road Train Member
    12,830
    53,680
    Mar 4, 2015
    What’s your manual say? I’d start there and test your oil at the recommended interval and adjust from there. No sense in dumping out good oil. I do filters at 20k and oil / filters at 40k. I could probably push mine out a little more but that’s what I’ve settled on.
    Dave_in_AZ, PE_T and 650cat425 Thank this.
  6. Ridgeline
    22,723
    123,063
    GET A BYPASS FILTER
    AND
    GET AN OIL ANALYSIS EVERY 15K.
    This will tell you when to change oil.
    Mountaintrucker4302 Thanks this.
  7. AModelCat
    164,482
    What's a "B service"?
  8. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    "B" service is a PM . "A" service is at longer intervals, and they can include replacing the engine coolant, differential fluid, trans fluid in addition to a B service. The components on an A service would be covered in the owner's manual/ service manual
  9. PE_T
    PE_T Road Train Member
    Service A & B are probably terms used by the OP’s company. If you want the full-blown maintenance, find the maintenance manuals for your truck make/model and your engine. Get ready because that list is exhaustive at least for the Freightliner Cascadia.
    Mountaintrucker4302 and Long FLD Thank this.
  10. D.Tibbitt
    156,840
    I do oil change and filter change every 12k. As well as grease truck and trailer every couple weeks.
    Dave_in_AZ and bad-luck Thank this.
  11. Accidental Trucker
    Accidental Trucker Road Train Member
    3,437
    7,789
    Jun 4, 2015
    I go by the "heavy duty" interval in the manual. If you look closely at who that includes, it's probably the majority of trucks.
    Dave_in_AZ Thanks this.
  12. bad-luck
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    I do it the same way oil and filters every 12K every 2 weeks grease the truck
    D.Tibbitt Thanks this.
