B train side dump good and bad
Discussion in 'Canadian Truckers Forum' started by Yves kanevil, Jun 28, 2016.
  1. Yves kanevil
    Yves kanevil Medium Load Member
    522
    465
    Jan 10, 2016
    Nighthawk
    Looking to replace and old end dump with something newer. Live bottoms are too much maintenance. Looking for people with side dump experience. Rtac btrain side dumps seem to be somewhat popular in western provinces. The materials being hauled are anything ng from concrete sand to 24" minus blast rock
  3. BigPerm
    BigPerm Medium Load Member
    I ran double 40' side dumps in Nevada. No big deal except for length and all the associated electrical & hydraulic issues. They we're Rancos, ( out of production now?). Gotta watch the back axle hub covers when dragging the rear trailer over larger material.
    Two man job to put a set together.
  4. Yves kanevil
    522
    465
    Jan 10, 2016
    Nighthawk
    When tilting was there any chance of tipping. I love using end dumps but because of too many drivers not paying attention and laying them on their side most jobsites around here don't want to see them anymore. Looking for and alternative to live bottoms
  5. BigPerm
    Yep...I've heard it's possible...but use common sense & try to stay off the pile or windrow. I really got pretty good at laying out an even row with a train.
    But...there again, when you start with both tubs rolled over before dumping..you gotta be on your game. It takes a while to get to know how quickly the boxes respond. Some lazy, others fairly quick. I had one of each in the set.
    Who Hoo.
  6. Mr. Premium
    Mr. Premium Bobtail Member
    32
    20
    Aug 11, 2016
    I'm a little late to this thread, but I can offer my $0.02, as I ran B-Train side dumps here locally for a few years.
    I've operated a couple of different brands, but I did prefer Side Dump Industries trains. They were very stable. They can flip, but I've only seen it once. Usually on soft ground, bad angle, and when the driver attempts to dump boxes at the same time. Dump one box at a time, on decent ground, and these things are virtually impossible to flip over.
    Steel boxes could handle anything just fine. I've hauled 24" Riff Raff, and the only concern with stone this big is that they can roll into things like the landing gear of the trailers when dumping. One trailer needed landing gear replacement due to Riff Raff rolling into it. Not an issue for "regular" gravel, though.
    Another pro is the ability to legally haul 42 metric tonnes of gravel (at least here). Cons? Not many operators know how to load these, and more often than not you'll be way over on the tri-axle bridge, while being under on the tandems.
    Also, I have seen people dump through tarps a dozen times. Unlike an end dump, forgetting the tarp and dumping will ensure tarp ends up at the bottom of 20 tonnes of dirt.
    Obviously length is a factor for local work, when many sites are just used to truck and pony's. Even some gravel pit weigh scales are only long enough for dump and transfer trailers, meaning with B-Trains it can mean the scale operator will have to bust out the calculator and weigh each half of the truck separately, to their dismay.
    The ability to dump right over concrete barriers makes them ideal for a limited amount of roadwork, which is something that an end dump cannot do.
    Also, it was not uncommon to park the A-Box, and run just the B-Box... This allows the truck & trailer to get into spots suitable for truck & pony's, with the net product capacity being only a tonne or two less than a truck and pony, therefor being able to bill an equivalent rate.
    THAT all being said, B-Train side dumps are, at least here, probably still best left for mainly highway work. Local work just can't always accommodate them properly... Most customers are simply used to a truck & pony, or a transfer.
    And at least for local construction work, it does take a good driver to maneuver these things around sites designed for truck & pony's.
  7. Mr. Premium
    32
    20
    Aug 11, 2016
    I should also add, that pulling 63,500kg through mud, sand, etc, is VERY hard on the tractor. Unless you have a heavy-spec truck with big power, think twice.
    A 12,000lb front won't really do, as I saw a half-dozen front leafs snapped. It's a brutal environment pulling that weight through muck. 46,000 rears, 14,600 front, 18 speed, full-lockers, and big power are really the minimum you should have for a combo like this operating in extreme environments.
    Side Dump Ind. trailers have a dozer push bar at the back. It will be used. You will also need a proper front tow hook attachment. Half the "standard" tow hooks on the tractors were broken off... You will want a really durable tractor tow point attachment. The "hooks" won't cut it for very long.
  8. BigPerm
    Only problem I had pulling double 40' side dumps was when hauling big nasty chunks of rock/concrete, you had to make certain the crap didn't take out the wheel hubcaps. C/R makes steel hubcaps vs: Stemco pot metal/aluminum.
    Management wouldn't listen. Two guys lost wheels!!
  9. Yves kanevil
    522
    465
    Jan 10, 2016
    Nighthawk
    The trout river industries side kick looks interesting. It's a side dump but the box seperates instead of going over the top. Gonna see if they can make a b train version
  10. Macneil
    Macneil Heavy Load Member
    711
    426
    Dec 15, 2010
    Sudbury, ON., Canada
    How come you're dead set on trains?
  11. Yves kanevil
    522
    465
    Jan 10, 2016
    Nighthawk
    Either rtac b trains or a 53 foot 5 axle looking and certain configurations with side dumps trains seem to be a better option because axles are out of the way on most part of the load being dumped. Probably would be easier on rims and hub caps with that spread. And when you wanna deliver in cottage coutry you just pin onto the pup. Winter it's better with one but chances are it would be mostly a spring summer and fall trailer. I busy enough with logging in winter that it can say out of the salt.
    Macneil Thanks this.
