Backing help
Discussion in 'Experienced Truckers' Advice' started by TooTiredToTalk, Apr 24, 2022.
  1. TooTiredToTalk
    TooTiredToTalk Medium Load Member
    636
    2,935
    Feb 24, 2022
    I need help backing. I mean I can back BUT I have never been able to set myself up for a back and it seems no matter how many videos I watch or how many people try to help, I'm just not getting it. I feel like I'm never going to get this....oh and for the drivers who knew I was doing flatbed, I had to switch companies for a bit to get more experience because the safety department of my boss's (former) insurance were having a ##### fit about me not having two years. So I had to go back to this stupid reefer crap as well for a bit. Currently headed to Illinois and then Jersey after that.
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    seriously, go out to a toy store, and buy a big rig toy truck, one that (if possible) the steers turn.
    set up an area that you can use maybe pencils or pens, or sticks, as the docking area.
    we can explain it to you, but it is easier for you to try it with the toy truck.
    i personally always tried to put my rig at about a 45 degree angle to where i needed to start my backing.
    that's about all i can help you with.
  4. KaoMinerva
    KaoMinerva Transcendent God
    3,565
    4,504
    Feb 5, 2016
    I got good at backing by simply practicing as much as I could. I also never back unless I have to. Now I pull doubles and I can back a set up a little. I've been learning it just like a van. I can easily back a pup trailer with a dolly behind it like it ain't nothing.
    Practice makes perfect...
    Todd727, MACK E-6 and TooTiredToTalk Thank this.
  5. Chinatown
    Chinatown Road Train Member
    77,549
    182,939
    Aug 28, 2011
    Henderson, NV & Orient
    Why didn't you go to another flatbed company?
  6. prostartom
    prostartom Light Load Member
    219
    467
    Jun 20, 2014
    Lawnmower and yard cart maybe? Not trying to be rude but that’s how I will teach my daughter when the time comes.
  7. Chinatown
    77,549
    182,939
    Aug 28, 2011
    I can put a 53' 102" anywhere. Trying to back a U-haul trailer with my SUV is a disaster.
  8. tscottme
    tscottme Road Train Member
    Practice is the key, watching videos can only show you WHAT you are supposed to do. DOING is what makes you better. You need to back the truck every single time you stop the truck instead of only backing the trailer when there is no other option. Look for 2 or 3 empty parking spots side by side. You are aiming for the middle of the 3 spots. If you can't find 3 spots then settle for 2 spots with painted lines. Back into that spot assuming you will be set on fire if your trailer tires TOUCH any of the painted lines. If you are stopping for food, go find a parking space and back into it before you do anything else. When you stop for fuel, get fuel and then go back into a parking space, every single time.
    Here is a Schneider video that shows what I try to do each time. You are better off watching one video and doing their procedure over and oevr and over rather than watching every video and getting confused. What I learned from flying airplanes is you are MUCH better off practicing exactly the same way over and over than you are doing it the same number of times but each attempt is different than any other attempt. Better to be always wrong in the same way, AT FIRST, and then fixing that mistake you keep making. When I started, and many times even today, I often wind up too close to the truck on the driver side of the parking space I am trying to park in. I know how to fix that mistake and I have good visibility while I am backing. So I just keep using my usual procedure as it keeps me from hitting the vehicle on the blind-side. Don't be your own worst enemy. That just discourages you and freezes you at the current level of skill. Keep getting more practice. Back into a spot every time you stop the truck until you can always back into the spot you want. I still get anxious when backing 30 years later. It's a job, not a spa weekend.
  9. tscottme
    short wheelbase vehicles are MUCH MORE DIFFICULT than a standard tractor and 53 foot trailer.
  10. prostartom
    219
    467
    Jun 20, 2014
    Ain’t that the truth. I have had 48’ trailers with a single screw day cab in all 5 boroughs of NYC. I can blind side alley dock pretty much 1st time every time.
    Borrow my buddy’s little utility trailer with my crew cab long bed truck and it takes me 10 try’s to get it backed in the same spot he can whip it in with his pickup.
    Sometimes he kids me by asking “Are you sure your a truck driver?”
  11. JoeTruck
    JoeTruck Heavy Load Member
    853
    3,393
    Mar 13, 2015
    LOWER 48
    No one has a magic formula.
    Every person sees it a little different.
    It's all about the set up.
    Practice every day and watch how others do it.
    It takes most people about a year to get used to the truck
    TooTiredToTalk and alds Thank this.
