Backing tips? Any advice before I hit something?
Discussion in 'Experienced Truckers' Advice' started by Dkenos, Sep 2, 2024.
  1. Dkenos
    Dkenos Bobtail Member
    48
    30
    Jul 7, 2018
    Recently, I have been having a hard time backing. I'm mostly doing it in areas with three spots (aiming for the middle), but Everytime I get out and look mid turn, the right side of my trailer is in the other lane. The company has been giving me weird loads and my tandems usually are all the way forward to keep weight legal. This means my back end is out more. I am doing the basic 45° backing where I make a 90° right until parallel with the trucks and then a 90° left until I'm perpendicular. This backing method does get me pivoting towards the hole, but I forget if I should focus on my tandem wheels, or my trailer when it's turning. Any advice before I hit something?
    austinmike and Flat Earth Trucker Thank this.
  3. Kyle G.
    Kyle G. Road Train Member
    3,901
    20,575
    Jan 23, 2016
    Eastern Iowa
    Don't aim for the middle hole, that just makes it harder for the next two guys after you, and leaves both sides of your truck exposed to potentially get hit.
    Aim for the hole on the far right (if you are facing them), so you will backing next to a truck on your left (sight side). This way, you can put more attention on your sight side. Not only will you find it easier to back in next to a fixed object instead of just a line on the ground, but the next guy will appreciate that you left two spaces for him.
    Other than that, keep getting out to look like you are doing!
    Hawkeye212, Oxbow, CassND and 7 others Thank this.
  4. Dkenos
    48
    30
    Jul 7, 2018
    These are all very informative. How does one account for the back swing when you're on a trip that requires tandems all the way forward?
  5. tscottme
    tscottme Road Train Member
    You avoid trouble with the tail swing by not making sharp turns when you are near objects/vehicles. You also look at both sides of the trailer rear & beyond it to vehicles that will soon be near the rear of your trailer. When backing into a tight spot you stop the vehicle the instant you don't see or know what is behind you. You aren't hired to back up at a quick speed you have a job to NOT HIT ANYTHING. If that means you go slower or stop then you go as slow as you need or stop as often as needed. Ditto when finding customers go as slow as you need & ignore the cars wanting you to drive 75 mph until the entrance.
  6. tscottme
    As soon as you improve backing start backing into 2 empty spots instead of 3. Back into the First empty spot beside a parked truck or trailer. That leaves an empty parking spot on your blindside or passenger side.
    The real key is to just practice backing into a spot every time you stop the truck. I never rode with my tandems fully forward unless that was required for weight distribution of the load. It's just inviting trouble. I mostly positioned the tandems for legal weight & "bridge law" or "kingpin to rear axle law" or state maximum for semi-trailers. I don't know your circumstances that are causing you to drive with tandems forward.
  7. Flat Earth Trucker
    4,313
    16,559
    Nov 19, 2018
    You can always reposition your tandems after avoiding any potential outswing issues.
    The_vett, 2Tap, Oxbow and 1 other person Thank this.
  8. abyliks
    abyliks Road Train Member
    4,110
    9,665
    May 2, 2010
    ludlow MA
    Put your tandems in hole 8-10 where they belong and you won’t have as much tail swing
    Ask yourself how the trailer would come out before it goes in
    Oxbow Thanks this.
  9. Opus
    132,221
    What helped me the most was self taught and took me years to figure out.
    Don't drive the trailer, drive the tires.
    It tends to simplify the whole deal.
  10. lual
    lual Road Train Member
    5,321
    9,700
    Oct 22, 2020
    SW Georgia
    "Tail swing" is actually a VER-RY GOOD THING -- just not with trailers....;) :p :D :tongue3:
    -- L
    Oxbow, mitrucker, Bean Jr. and 4 others Thank this.
