Bad exhaust temp
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by smfry, Apr 10, 2017.
  1. smfry
    smfry Bobtail Member
    18
    Lansing, IL.
    Trying to get a Volvo with a cummins ISX to regen but cant get temps above 275° . checked all sensors turbo, egr... Ready to start a fire...
  3. DIESEL47
    DIESEL47 Bobtail Member
    Hydrocarbon doser maybe?
  4. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    Probably not the fuel doser, that's not hot enough for it to even start dosing. Did you check for exhaust leaks? What is the coolant temp? If this is a CM871, check injector cam timing. Those engines had lots of cam timing issues preventing parked regens because they can't build enough heat. Most of the time, if the cam timing was set wrong, the air compressor is noisy when building air. I'm not sure why, but I've fixed a dozen or so for that same issue and once timed correctly, the compressor quiets down and it starts building enough heat to regen. If the compressor makes noise and gets quiet as soon as it unloads, retime the injector cam.
    SAR Thanks this.
