bad fuel?
Discussion in 'Volvo Forum' started by mj5219, Jan 17, 2013.
  1. mj5219
    mj5219 Bobtail Member
    12
    Aug 23, 2012
    I have a volvo ved12 2005 and I think I picked up some serious bad fuel, I was puttering and stallingg out about halfway through the day,the day after, I had to stop and prime it for a few minutes everytime it would die, the next day I replaced both fuel fitlers and ran well for half of the day and then the same thing happened? I always get it started again and it runs fine for a couple miles before it starts puttering and stalling out. Sometimes I get clear white smoke coming out of the stacks and sometimes I don't. My question is has anyone ever gotten fuel thos bad or does this sound like something other than bad fuel any input or advice would be greatly appreciated
  3. mj5219
    12
    Aug 23, 2012
    Also my fuel filter water separator keeps filling up with cloudy diesel ive been sitting here for an hour constantly draining it
  4. baggedextreme
    baggedextreme Bobtail Member
    30
    4
    Jan 9, 2013
    Hope mills nc
    sounds like bad fuel or some kind of trash running through the filters and stopping them up the filters will more than likely need to be replaced again along with cleaning the tank and putting fresh fuel in the tank
  5. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    You have any enemies that may have spiked your tanks with sand or sugar?
  6. mj5219
    12
    Aug 23, 2012
    I'm starting to wonder that I did have this crazy ex that had messed with my vehicles, before what could I do if that we're there case
  7. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    The shop that I take my truck to had a Freightliner inside with the filters and fuel lines disconnected and lying on the floor. Beside them was a pile of granulated sugar / diesel fuel mix that they had dumped out of the filters. They were in the process of scooping sugar out of the tanks. Apparently the former driver wasn't happy with what he was being paid to yank containers around, so he sabotaged the truck.
    Look in the tanks with a flashlight - if there's major contamination you should see it on the bottom of the tanks.
    It's also possible that you got a load of biodiesel. Bio will wash all the collected and built-up crud out of your fuel system and into the filters. If that's the case, you'll just have to keep changing filters as they plug, until the crud has been cleaned from the system.
  8. 25(2)+2
    18,749
    45,444
    Sep 18, 2006
    the road less travelled
    My guess would be water in the fuel; if the water is dark gray or black, there is probably microbial growth. If the station tank was just filled before you filled out of it and there was water that didn't settle out, you might have gotten a good shot of water contaminated fuel, the white smoke could be water causing the engine to miss because it is overwhelming the water separation capacity of the filters. It happened more in years past, and not just with diesel.
    I got a bad fuel up once from a recommended fuel stop, less than 50 miles and the truck wouldn't run,the filter was clogged with gunk.
    It was the Cummins fuel filter on an ISX, filters to a smaller particle size. I don't know how particular a Volvo engine is about fuel, the ISX is particular.
  9. sbaumann14
    sbaumann14 Road Train Member
    1,221
    1,409
    Sep 1, 2010
    Rhinelander, WI
    where u at? 10 degrees at home today. biodeisel will start to gell at that temp
  10. mj5219
    12
    Aug 23, 2012
    I'm in Pa, it's about 32 where I'm at not too cold, it's been running fine this morning So far, I used alot of dry gas and must have drained over a gallon and half of ###### fuel mixed with alot of water from my separator pretty crazy hopefully today is better than the previous
  11. mj5219
    12
    Aug 23, 2012
    BTW thanks everyone for your input, I've only been driving for a year and this volvo has been a nightmare lol
