bad ground ?
Discussion in 'CB Radio Forum' started by cuzzin it, May 28, 2013.
  1. cuzzin it
    cuzzin it Road Train Member
    3,642
    12,267
    Jan 19, 2008
    Berea, KY
    i started getting static when passing power lines, and noticed receive range was very short. At first i thought that i had damaged the coax by shutting the door on it. So i changed it. Antenna looked good so i ruled that out and swr still looked good. i switched radios and problem is the same, and has gotten worse over time. Someone said they had same problem and it was ground issue that he grounded back of radio to steel frame and that corrected it
  3. Luwi67
    Luwi67 Heavy Load Member
    750
    485
    Oct 24, 2012
    Long island
    The radio is grounded via the power cable and, should be strait to the battery pos and neg.
  4. MsJamie
    MsJamie Road Train Member
    Putting a ground strap from the rig to frame may help, but your rig may well already have that from the mounting bracket.
    Since the problem is getting worse, my guess is that the door is losing its bonding to the frame. If you don't have a bonding strap between the door and the door frame, you are using the hinges to provide that bonding. As hinges wear, they don't do that so well.
  5. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    high SWRs will cause a significant drop in reception as well. line noise is line noise. have the SWRs been checked recently?
  6. cuzzin it
    3,642
    12,267
    Jan 19, 2008
    Berea, KY
    Wouldn't that give me high SWR and bad static transmit ? no one is telling me i sound bad or squeel
    Mounting bracket doesn't go to metal, it's self tapping screws into plastic plate of the overhang where the terminals poke through. It worked fine until recently... so i guess that's not it
  7. MsJamie
    Not necessarily. Many of these antennas are designed to give low SWR when used against a poor ground. I've seen cases where improving the ground caused the SWR to go up.
  8. mike5511
    mike5511 Road Train Member
    3,155
    1,546
    May 15, 2011
    NW Arkansas
    Haven't heard that before. Which antennas would these be?
  9. cuzzin it
    3,642
    12,267
    Jan 19, 2008
    Berea, KY
    Ok so the plot thickens..... Today i went on gravel road with some of the best potholes money can buy. And Radio noise lessened quite a bit...... go figure
  10. mike5511
    3,155
    1,546
    May 15, 2011
    NW Arkansas
    Things were bouncing and rubbing together producing a better ground? :dontknow:
  11. Rat
    Rat Road Train Member
    There is some metal in the over hang that you can ground too if you want. You don't really need a strap for such a short run to ground. I have used 10 guage wire for short runs like this and it has worked just fine. I would look more at chassis grounds though and also check to make sure that coroation has nto made its way into your antenna bracket. I have had it build up in the empty space inside the plastic washer and actually short out the antenna. Take the antenna mount apart and clean everything up. If you see white crap in there then that may be causing issues. You want good clean shiney everything.
