Bad head
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sam jones, Apr 24, 2015.
  1. sam jones
    sam jones Bobtail Member
    13
    Aug 11, 2013
    I put a reman head on my 02 6nz and pressure tested it at 6 pounds and fund that it was leaking coolant out of the exhaust port on the number 1 cylinder dose this mean I got a bad head.
  3. 77smartin
    77smartin Road Train Member
    2,183
    3,024
    Apr 3, 2011
    I dunno.
    I was going to but......
    tucker Thanks this.
  4. tucker
    tucker Road Train Member
    12,647
    40,425
    Jun 13, 2008
    IN
    me too. I'll be mature today
    77smartin Thanks this.
  5. sam jones
    13
    Aug 11, 2013
    What's that supposed to mean.
    tucker and 77smartin Thank this.
  6. Ezrider_48501
    3,845
    5,133
    Apr 2, 2011
    bismarck, nd
    i wont be as mature as the others.....
    don't you just hate it when you get bad head. such a let down.
    it does sound like there is somthing wrong with the head. im not sure how coolant would get directly to the exhaust port without a crack in the head unless its spitting out coolant on the exhaust cycle.
    77smartin and sam jones Thank this.
  7. sam jones
    13
    Aug 11, 2013
    Well one person I talked to said it could be a cracked liner would that do it?
  8. Bent Wrench
    Bent Wrench Medium Load Member
    588
    205
    Aug 11, 2009
    Cornholio, OR
    Well if you take the rockers off that cylinder and it still comes out the port it's not a liner.
  9. BoxCarKidd
    BoxCarKidd Road Train Member
    4,541
    6,619
    Aug 26, 2014
    Possibly a pin hole in liner in area of top of piston or rings when piston it is all the way down. Would likely get coolant in oil also. Loosen plug and check after parked overnight. Why was the head replaced to start with? Was the number one an odd color compared to the others when the head was removed? When you tested this was the engine running?
  10. me myself and I
    me myself and I Heavy Load Member
    735
    312
    Oct 5, 2009
    vernon hills,Il
    Still better than none..:biggrin_2556:
    tucker Thanks this.
  11. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    either way the head will have to be removed. if it was a liner you will see antifreeze running down the liners when you remove the oil pan. as well with a cracked head. did you just install the head? could have screwed up one of the rubber grommets for the water ports. or if you didn't check liner protrution have a dropped liner issue.
