Bad Injector?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by DRN2001, Dec 17, 2023.
  1. DRN2001
    DRN2001 Bobtail Member
    11
    Dec 14, 2023
    Eastern MT
    My Cat Challenger tractor with a 3176 in it has been sitting a while. I noticed yesterday there's fuel dripping out the back of the turbo. I'm hoping it's just a bad injector! If you change one injector, do you have to change them all?
  3. AModelCat
    163,805
    Just change the failed one if that's the issue. You sure its fuel and not oil slobber out of a failing turbo?
    Rideandrepair, BoxCarKidd and W923 Thank this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,541
    6,619
    Aug 26, 2014
    Years ago I worked for a company that only changed air filters by restriction gauge reading. If it is high in the yellow just reset it this PM as it could be from rain.
    A truck came in for regular PM with no complaints. It was dripping oil out the exhaust flex pipe. Supervisor said the turbo is bad replace it. I did and it still dripped oil out the flex pipe. Pulled the records and went through it. Filter had over 400,000 miles on it. Pulled it out and it was all packed up and had one bird in it. That ended the exhaust dripping oil. Would have thought it would have low power complaints, blowing black smoke, etc.
    Never say always and always say maybe. Wonder how much fuel and engine wear that cost.
    Rideandrepair and DRN2001 Thank this.
  5. DRN2001
    11
    Dec 14, 2023
    Eastern MT
    Thanks.
    I looked a bit further (after panicking) and the oil pan was full of diesel. I drained and changed the oil. I disconnected the exhaust at the turbo and the fuel poured out. I'm thinking it must have been being blown in there while I was running it last because I don't think it could've gravity flowed that far into the exhaust.
    I'm just waiting for the temp to come up a bit today and am going to head out and take the valve covers off and try and dry out any fuel in there. Then I'm gonna put gas glow in the fuel filter and start her up and see if I can see any glowing stuff on any of the injectors...
    Rideandrepair Thanks this.
  6. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    Pull the manifold off and look for the smoking hole.
    Rideandrepair and AModelCat Thank this.
  7. Rideandrepair
    17,514
    56,757
    Aug 8, 2015
    I had one fail on my Detroit. Put 10 gallons of fuel into the pan before shutting down. Finding the bad injector was simple. The solenoid was leaking, squirting fuel out. Very obvious once I pulled the valve cover off. Another time, I had a blown tip, fuel was dumping into exhaust. The exhaust manifold gasket was all wet from fuel seeping around the bad port.
    BoxCarKidd Thanks this.
