Barely over 80k
Discussion in 'Truck Stops' started by 7milesout, Mar 3, 2021.
  1. 7milesout
    7milesout Bobtail Member
    23
    31
    Jun 2, 2020
    Folks, maybe this is dumb to ask, I've not been put in this situation before. I'm going to keep the particulars nameless to protect the guilty. :D
    OK, O/O here. I took on my normal live(load), won't say what it is or from where, doesn't matter. Just usually feels lighter. Paperwork made everything look legit. This time after loading I was curious (and MT on fuel) so I ran down to the nearest truck stop / scale.
    I rolled in and ... yes, I ran across the scale first. 79,210 lbs. Bone dry on fuel. Somebody doing the paperwork fudged something or is just plain dumb. Gonna set somebody straight next time I load there, and show them my actual weights. Former engineer here, I haven't been driving for too very long. I didn't want to retire and sit around and do nothing. So I bought a truck some time back (after driver school) and just stood around and waited for some broker to say, "hey you!" So now I just roll around from time to time, bash into things and keep the commercial girlfriends employed and covid-infused. I know that D2 is about 6.8 lbs / gallon average depending on specific gravity, blah blah blah.
    So I took on 115 gallons of fuel. Ran across the scale again, now I'm at 80,015 lbs. I'm carrying only about half the fuel I can. Course that is a PITA, but my truck runs in the low 8's usually (since I'm in no hurry) so I'm good for a day and a half or so, I'll live having to make an extra stop before I deliver.
    I'm not too worried about getting pinched before I can burn off 15+ lbs of fuel. But if we were to ever roll through a weigh station at 80,015 lbs, would they be going to go apesheeeit? Any way to explain our way out of such (hey uh, 18 miles down the road and I'm going to be 79,999 lbs, or I could idle here about 3 hours and run a couple regens... :)). Or should I be prepared for an award?
    7milesout
  3. jamespmack
    216,477
    It would be of zero concern to me. Your fine. Roll on.
    alds, buddyd157, nredfor88 and 5 others Thank this.
  4. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    DOT scale is 500 +- as they told me. Anything over they write the ticket. CAT scale always will show lil more then real to avoid WE WILL PAY YOUR TICKET
  5. Numb
    Numb Crusty Curmudgeon
    4,312
    10,232
    Jan 30, 2012
    Charlotte, N.Carolina
    unless you know the company ,always fuel before loading
  6. mpd240
    mpd240 Road Train Member
    1,540
    3,625
    Sep 17, 2011
    Minnesota
    Weights will very Depending on what your hauling. Commodities such as lumber swing dramatically depending on moisture. Steal and concrete also very more than you think.
  7. 7milesout
    23
    31
    Jun 2, 2020
    Good advice.
    In this case, it doesn't really matter. How to say ... they're sort of winging it about how much weight they're loading on. They're not a horrible place though. If it was way yonder too much, say I was at 82k lbs, I'd just take it back to their dock and have em pull some out. Hasn't happened yet.
    When I say it doesn't matter, if I had fueled (full) before hand, I would have wound up at like 700 lbs over I suppose. They wouldn't know if I was full of fuel or not, they would have loaded what they loaded either way.
    Numb Thanks this.
  8. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    There is always a variance on the scale, 15lbs is well within the variance. Heck, I've scaled, slid tandems and rescale and the gross was off by 20-40 lbs...
    jamespmack Thanks this.
  9. Hammer166
    7,602
    27,772
    Aug 18, 2007
    ~8600+' and loving it!
    @7milesout, it's much safer to just use 7 lb/gal. 6.8 is the bottom of #2 range, it can be as much as 7.3.
    6.8 is safe to use up north in the winter due to the #1 blended in.
  10. sealevel
    sealevel Road Train Member
    2,664
    10,282
    May 31, 2012
    U.S. 41
    A few months ago I picked a load that was supposed to weigh 42360. It weighed 48970. Even had 48970 on the BOL. Scaled it and was 2900 over gross, all on the drives with the tandems all the way up. 250 miles for 2100 dollars. Shouldn't have run it out of principle, but I know the back woods of Ga pretty well.
    If your a O/O I wouldn't try to set your customer straight over 15 pounds.
  11. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    I hate scale dodging but i'd do it all across the country for 8$/mile :p
    alds and Cattleman84 Thank this.
