barring over a 3406E cat engine.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by lciambotti, Mar 2, 2022.
  1. lciambotti
    lciambotti Bobtail Member
    22
    6
    Mar 2, 2022
    Etters, Pa
    I'm purchasing a 96 T680 that has been sitting for a couple years. I want to bar the motor over and make sure its not locked up. I know how to do a cummins but a cat is new to me. Any help would be appreciated!
    Thanks!
  3. wore out
    wore out Numbered Classic
    17,295
    214,450
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    There is a place on the rear structure to put the engine turning tool or a 1/2 inch drive ratchet and a shallow 15/16 socket on one of the balancer bolts. Standing on driver side you want to pull it to you or tighten the bolt
  4. lciambotti
    22
    6
    Mar 2, 2022
    Etters, Pa
    I'm going to look today for where you are talking about. Hopefully its not locked up. I charged the batteries and the starter tried to kick the solenoid out but I don't think it engaged. And I couldn't wack on the starter and hit the starter button at the same time.
  5. Big Road Skateboard
    7,081
    40,122
    May 2, 2021
    Use a pipe wrench on the balancer. You'll surely see marks where everyone else has.
    lciambotti Thanks this.
  6. Lazer
    Lazer Road Train Member
    1,848
    2,978
    Jan 22, 2017
    Don’t be surprised if it needs new batteries, I’ve been where you are, charge batteries for a couple days, hit starter and just clicks, clean all connections, charge another day, same result. Switch out 3 brand new batteries, hit starter and it fires right off.
  7. p608
    p608 Road Train Member
    2,181
    2,993
    Nov 10, 2016
    That's why you test them, coulda saved yourself 2 days
  8. Lazer
    1,848
    2,978
    Jan 22, 2017
    Well, the boss man said to bring back to life with the charger first.
  9. lciambotti
    22
    6
    Mar 2, 2022
    Etters, Pa
    Yea. I'm going to test them tomorrow. On another subject, the guy I bought it from said the fuel came out of the top of the filter where the rubber gasket is when it was running. He said he changed filters a couple times but that didn't do anything. Any thoughts?
  10. Lazer
    1,848
    2,978
    Jan 22, 2017
    Could be a hairline crack of the filter housing.
    Could also be, possibly there is two gaskets? Maybe filter was changed, but the gasket stayed behind tucked into the grove that the gasket goes up into? (depending on the style of filter housing)
    RefMata Thanks this.
  11. pavrom
    pavrom Road Train Member
    3,215
    7,408
    Apr 29, 2012
    NE illinois
    96 t680?!
    p608 Thanks this.
